Question about X2Gen MG19VT 19" LCD Monitor
I need the power supply. where can i find one.
Plz reply with proper details of the problem. nothing is clear about the problem yet.
Posted on Jun 19, 2009
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Apr 08, 2010 | Dell 200W ATX Power Supply GX1 - GX110...
I need a manual or product number for power supply power supply order #
No you don't. If you think the power supply is bad, then unplug it, unscrew it, and take it to a discount place like Fry's to simply match it. Compaq does not make its own power supplies, so they use generic ones, like everyone else does. The only thing you have to choose is how many watts you need. The original may have been rated too small if it went bad, and you many want one with more power, like 500 watts.
Jan 17, 2010 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Switching power supply ??
For your purposes there is no difference: all you need to know is the voltage your WD drive requires, and the maximum current load it needs. Any regulated DC power supply with that voltage and *at least* that current will do.
Not-so-technically, a "regular" power supply will supply power at the correct voltage by "discarding" a portion of the extra potential. A "switching" power supply will shunt and switch the extra power away, so that instead of being "lost", it is "not requested" from the uplink grid. In theory a perfect switching supply will have no losses, and therefore dissipate no waste heat (in practice there will be some losses, and cooling will be needed). The important thing, though, is that a switching power supply can deliver twice as much power as a "normal" supply, and the same power in a half as big package.
Jan 03, 2010 | Computers & Internet
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
MY BROTHER JUST GAVE ME THIS MOTHERBOARD FOR MY EMACHINE AND SAID IT CAME OUT OF AN EMACHINE, WHAT POWER SUPPLY DO i NEED TO INSTALL? Intel D845EPI Motherboard
i have seen those in some emachines but the original power supply stinks the processor needs a power supplie the has at least 300 watts but 400 plus is a better choice depending on which emachine case to have it might need ti have the case modded to fit a larger power supplie some emachine case have a plate mounted the allows both power supplie type to be used the small power supplies are garbage so go with the larger p4 power supplie most all should be able to be modded to fit in you case. Just remember the more power in mean the more power out.
Jun 10, 2009 | Intel Computers & Internet
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
X2Gen MG19VT 19" LCD Monitor Logo
135 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
