Question about Kenwood VR-405 Receiver
Sub not working in stereo
Two large speakers left and right sub not working. Works in set up
killer_clown
  • 86 Answers
SOURCE: Center speaker and sub stopped working
if the sub was popping that either means the sub is getting to much power and blown that normaly happens when they pop, for the center speaker could check the wires maybe it came undone that could be a possibilty
Posted on Nov 16, 2008
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: cant get sound from right and left rear speakers
Your source will determine the Dolby Digital capabilities. WHAT is on video 1 and is it Dolby Digital?
Posted on Jul 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sub woofer output port does not seem to work on my
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Posted on Dec 29, 2010
dunnbiker
  • 8546 Answers
SOURCE: hi hows it going i have a kenwood vr-8060 6.1
The manual will show you how to enable, test and adjust the Subwoofer Output.
http://www.retrevo.com/support/Kenwood-VR-8060-Receivers-manual/id/480ci254/t/2/
Posted on Jan 11, 2011
My sub ksw10 do not work with avr589.sub is fine.av receiver works on all 5 channels.with the remote i am unable to adjust all the parameters.
http://usa.denon.com/DocumentMaster/US/AVR-589-OM-E_105A.pdf you'll need to access the receivers speaker Set-up menu. you can download the user manual here. my opinion is that your speaker setup in the menu is not correct. make sure that you have Subwoofer yes selected in the menu, also if you selected ( Large ) as your left and right Main speakers it will not allow you to select Subwoofer ( yes/no ). you must select ( Small ) and then select Subwoofer Yes. also you can connect all speakers and perform Auto setup and it will recognize the sub when a test tone is emitted.
Apr 20, 2011 | Audio Players & Recorders
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
How to set up to stereo ?
Generally there is a left and right input. The sub is usually not in stereo, the frequences of the sub are more omni directional, and have no spattal placement in the stereo field. If there is only (1) input you can take either the left or right from the system and you should get the frequencies you need. In the even it is not working out quite right you may take the left and right and use some 1k to 4.7k 1/2 watt resistors connected to tie the left and right line output togeather to feed the sub.
Dec 24, 2010 | JBL S120PII Subwoofer
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Can't get the subwoofer to work when the fronts are set LARGE?
The manual implies that 'subwoofer=Yes' is independent of the rest of the speaker settings, but that it would be set AFTER selecting the other speaker configuration from the list of 11 possibilities.
Jun 08, 2010 | Sherwood RD-6106 Receiver
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Wiring sub on home theatre
use the sub pre out and wire it into the left input on the sub.
Mar 08, 2008 | Audio Players & Recorders
Kenwood VR-405 Receiver Logo
21 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
