Question about Canon imageRUNNER 400S Copier
Canon imagerunner 400 showing e005
On the disply(put power on and off)and then e005
How do you get in Service Mode?
Posted on Jun 25, 2009
    President:
  • 1,126 Answers
E005 error means Fixing Unit Cleaning Web needs replaced.
Then a reset nedds to be performed after replacement. Unfortunately, you will need to get into Service Mode to reset the code.
Posted on Jun 19, 2009
HOW DO YOU GET INTO SERVICE MODE?
Posted on Jul 13, 2012
I have canon IR 400 M/c. Now It is showing Error E005 As per instruction on panel. M/c OFF and On. But no use Its shows E005 error
that is the lifetime of WEB CLEANENG is over. which position is in heater unit
this is a picture of heater unit.
you must replace a new of web cleaning.
this is a picture of web cleaning.
or sensor of web cleaning doesn't work.
if it,s the problem you just clean up with alcohol spray.
please try it.
May 28, 2011 | Canon imageRUNNER 400S Copier
Main power switch off on, E005, canon gp 335
E005 means that the cleaning web needs to be replaced.
May 29, 2010 | Canon imageRUNNER 400S Copier
My canon ir 330 has E005 the screen is totally locked out
This code means that your fuser cleaning web has run out and needs to be replaced. You will need a service call to perform this. A general cost estimate should be around $125 to $150 for parts and labor.
Oct 21, 2009 | Canon imageRUNNER 400S Copier
Remove canon copier problem e005 np6330 on display
You will need to replace the cleaning web that rides above the upper fixing roller. There is a sensor that reads the amount of web left... Good Luck
Jun 11, 2009 | Canon imageRUNNER C3200 Copier
To remove E005 in canon 6330
You have reached the end of you cleaning web. My copier tech leaves extras. It is not difficult to replace, but it in the fuser area so it is very hot. It would be best to have a tech replace it and show you before trying to replace for the first time.
If you have a cleaning web and need instructions on how to replace it let me know.
Jun 11, 2009 | Canon imageRUNNER 105 Copier
How do I fix a broken fixing film
You don't have to fix the fusing film on a Canon IR-400, it dose not have one. It has a upper and lower fixing rollers. But it does have a Cleaning Web and it would show on the display that the web needs to be replaced or it codes out with a E005. Afixxing film is on a IR-200 & IR-210 & IR-2200 & NP- 1625 series
Nov 17, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
637 people viewed this question
old marine
old marine
