Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Drive belt tensioning
See diagram
Passat 1998,4cylinders, turbo, what is the belt routing diagram, the power steeling belt is related with the water pump or not, thank you
The ancillary belts routing diagram for a 1998 VW Passat 1.8 Turbo
AC = Air Conditioning
CS = Crankshaft
F = Fan pulley
G = Generator
PAS = Power Assisted Steering
T = Tensioner pulley
WP = Water Pump
1. Viscous coupling removal (lock the viscous coupling).
2. Lock the ancillary drive belt tensioner.
3. Lock the coolant pump.
4. Remove the coolant pump drive belt.
5. Remove the ancillary drive belt.
6. Release the A/C tensioner if vehicle is equipped with A/C (Air Conditioning).
7. Remove the A/C compressor drive belt.
Aug 09, 2011 | 2004 Volkswagen Passat
Belt diagram
Accessory Drive adobe.gif Printable View (62 KB) Component Locations 3.0L (2V)a0007698.gif
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Coolant pump pulley
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8A528 Coolant pump pulley 4 8W508 Drive belt tensioner pulley
Nov 28, 2010 | 2004 Ford Taurus
Serpentine belt diagram 2002 ford escape picture of serpentine belt pattern
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/escape/2002_ford_escape_drive_belt_routing_diagram.htm
Feb 27, 2010 | 2002 Ford Escape
Need drive belt diagram for 3.3 dodge van
Below is the diagram you requested. It's for a 3.3L with AC. If you need the diagram without AC, post back with the request and I'll track it down 4 you. Best of luck!
Greg
99 Caravan 3.3L Serpentine Belt
Nov 13, 2009 | 1999 Dodge Caravan
2001 suburban. how to change a/c belt
2001 Suburbans generally have two belts. The primary drive belt and the A/C compressor belt. You must first remove the primary drive belt before removing the A/C belt. They are both kept in place with a tensioner. A standard 3/8 rachet will help give you the leverage to disengage the tensioner and remove the belt. Replace in reverse order.
Jul 30, 2009 | 2003 Chevrolet Suburban 1500
Diagram of a serpintine belt on a 2007 ford taurus se car
Accessory Drive Belt adobe.gif Printable View (140 KB) Removal and Installation
  1. Using a suitable belt tensioner release tool, rotate the drive belt tensioner clockwise and remove the accessory drive belt.
  1. NOTE: Refer to the illustration for correct accessory drive belt routing.
    To install, reverse the removal procedure.
May 23, 2009 | 2008 Ford Taurus
Need belt schematic for 2006 toyota corolla
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
Nov 29, 2008 | 2006 Toyota Corolla
Diagram for fan belt repair
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Aug 25, 2008 | 1998 Ford Escort
Belt diagram
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator 3 6B217 Drive Belt Tensioner Pulley 4 6B209 Drive Belt Tensioner 5 3A733 Power Steering Pump Pulley 6 19703 A/C Compressor 7 6312 Crankshaft Pulley 8 8509 Water Pump Pulley
here is the routing diagram of the 3.8 L on the 95 windstar
Jul 30, 2008 | 1999 Ford Taurus
Serpentine belt replacement
2.0L Engines
Jul 24, 2008 | 1999 Ford Escort
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
14 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
