Question about Refrigerators
Turn off the water dispenser
How do I turn off the water in the door
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker and water dispenser
If the refrigerator water dispenser is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 06, 2014 | Samsung 33 in. W 24.7 cu. ft. French Door...
Refrigerator water dispenser has water to bottom of door but will not dispense
water is frozen up in door. try turning temp to freezer up a little.
ive been able to thaw line by using hair dryer on inside of freezer door
Mar 11, 2013 | Frigidaire FSC23F7DSB Stainless Steel Side...
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Is there a tube or "tip" that fits over the water spout in the door water dispenser?
No, your tube may be too far up in the dispenser causing it to splash or dribble. Try turning the water to the refrigerator off then push the water switch while pulling the dispensing tube to see if that will bring the water tube closer to the dispensing area.
Mar 09, 2010 | LG LFX25960ST Stainless Steel French Door...
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
