Question about Kohler K-10577-4-SN Bancroft Widespread Lavatory Faucet with Metal Levers...
Kohler widespread faucet repair - Kohler K-10577-4-SN Bancroft Widespread Lavatory Faucet with Metal Levers...
  • Ronald Thompson Dec 26, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
  • 5 Answers
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Kohler K-12265-4 widespread bath faucet
It will be easier if you remove the etscheon and they should turn off but getting a grip on them with out ruining them is very hard...
using the deep socket may be a better option if the etscheon gives you a hard time....these things are always a challenge and often require you to improvise on the fly...
heatman101
Posted on Nov 20, 2010
  • 83 Answers
SOURCE: Kohler Finial K-310 Widespread Lavatory
should be able to turn the bottom piece under handle and it comes off along with handle..dont think theres a little "cap" that comes off at top of handle..but mite try prying it off it just has an o ring holding it in place and screw will be under that
Posted on Nov 25, 2010
Dplumber
  • 119 Answers
SOURCE: cant figure out how to
Turn the base of the Kohler handle counterclockwise until it is removed from the valve's escutcheon mounting nut.
Posted on Dec 14, 2010
How to fix a locked-up hot water handle?
Hello friend,
ALL of these taps (im english !!!) faucets ? have a LIFETIME guarantee. see http://www.faucet.com/kohler-k-8201-4-polished-chrome-taboret-centerset-bathroom-faucet-includes-metal-pop-up-drain-assembly/f230779#warranty-info
'To obtain warranty service, contact Kohler Co. either through your Dealer or Plumbing Contractor or calling 1-800-4-KOHLER or by writing: Kohler Co., Attn: Customer Service Department Kohler, Wisconsin 53044 U.S.A'
Worth a try !!! even if only to find out how to get them apart !!!!
Sep 14, 2014 | Kohler K-8211-4-CB Taboret Widespread...
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
How do I get the handle off so I can tighten it up to eliminate wobble
look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
Sep 16, 2011 | KOHLER Forte Widespread Lavatory Faucet...
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
Our Kohler K-454-3S is leaking when we shut it off.
replace the (either) O rings or washer, if its a washer setup I recommend replacing the seat also you can click on this link to see a normal repair for your problem ,, http://www.youtube.com/watch?v=ubp2W-3thOo Please take a moment to rate my reply and research for your problem,, Thanks Good Luck
May 08, 2011 | Kohler K-454-3S-AF Memoirs+ Widespread...
Kohler parts - plumber told me the ceramic ring in the faucet is broken- and that's why it is dripping. I am trying to piece out parts to fix myself on Kohler diagram - what is the ceramic ring called?...
hi, just had a quick look and the part you would have to source would be :78125 spline adapter. this is shown here...... http://www.us.kohler.com/onlinecatalog/pdf/1146603_2.pdf the taps are washerless ceramic valves and pretty good quality, are they still covered under warranty as i would imagine that part is not cheap.
Jan 14, 2011 | Kohler FortĀ© Widespread Lavatory Faucet...
Cant figure out how to remove right handle of kohler bancroft widespread lav faucet part # K 10577 4.
Dec 14, 2010 | Kohler K-10577-4-SN Bancroft Widespread...
Kohler Finial K-310 Widespread Lavatory Faucet. How do I remove the Lever Handle (77887) and Bonnet (75601) so I can replace the washers.
Nov 24, 2010 | Kohler Finial Traditional Widespread...
How do you get the handles off the Finial Traditional faucet so that I can tighten a compression nut?
Grasp the base of the handle under the lever by hnad and turn it counterclockwise. If the whole valve turns, you will need to hold the valve from underneith the sink with a wrench while you unscrew the handle base on top. It is difficult to see, even with the Finial owners manual from Kohler how the two join.
Oct 18, 2010 | Kohler Finial Traditional Widespread...
Kohler K-10577-4-SN Bancroft Widespread Lavatory Faucet with Metal Levers... Logo
42 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
