Question about Samsung LN32C530 32 in. TV
Set turns itself off and on repeatedly
Set turns itself off an on repeatedly and will not respond to remote commands to turn on.
My TV turns on and off itself repeatedly.
This can be caused by settings connected to the computer.Billion tv screens tend to switch themselves on and off sometimes.Read the manufacturer manual or see a pecialist when it persists.
Jul 21, 2016 | Televison & Video
I have a Sony TV and purchased a RCA remote control new from Walmart (as a replacement for a Sony remote control). The RCA worked fine for 2 months until I accidentally hit the wrong button. The little...
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2008 | Computers & Internet
URC20 D1F codes for philips tv
Not sure which Philips TV model you have. But you can use the remote to scan the code by itself.
Try these steps::
1. Manually turn on your TV. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
2. Push the power button repeatedly until the TV turns off, then hit "Enter."
3. Press any other button while the TV is on to see if it responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps
Aug 17, 2014 | Televison & Video
How do I program a dvd code into my crk76ta1 remote and what are the codes to a toshiba dvd
Hi, i have found the codes and instructions.
Toshiba Codes - 2015.2049, 2051,2055, 2065, 2093, 2116
I. Turn on the component to be programmed.
2. Press and hold the button on the remote you want to program.
3. Enter the code from the code list.
4 Release button, and then press ONeOFF to see if the component responds to the remote commands. If it doesn't, try pressing the component button and then ONeOFF again.
5. If you get no response, repeat these steps using the next code listed for your brand, until the component responds to the remote commands.
If none of the codes work then try a code search. Instructions below.
The following instructions can be used to program the remote to control each of the devices connected to your TV. If you want to exit the automatic code search without programming any of your devices, press and hold CLEAR until the LED turns off.
I. Turn on the device you want to control (VCR, SAT, etc.)
2. Press and hold the button you want to program (VCRI, VCR2, etc.) While hold'Ing the device button, press and hold ONeOFF until the red light on the remote turns on, then release both buttons.
3. Press and release PLAY, then wait 5 seconds or until the LED stops flashing. At this point the remote is searching for the correct code to program. If, after 5 seconds, the device you want to control does
not turn off, press PLAY again to tell the remote to search the next
set of codes. Continue pressing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device. If the device you want to control does turn off:
I . Press and release REVERSE, then wait 2 seconds. Repeat this step until the device turns back ON.
2. To finish, press and hold STOP until the red light on the remote turns off.
Feb 12, 2011 | RCA Televison & Video
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
3. Press and release the TV button you want to set up
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
Cant us the remote dont know how to accss the
These are the steps on how to program your Universal Remote Control to your device even without the list of code.
1. Manually turn ON your device.
Jun 14, 2010 | RCA Universal Remote Control
Need code for mitsubishi tv
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  3. Press and release the TV button you want to set up.The TV button will flash once.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | RCA Universal Remote Control
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Try this if so
Programming a Device using Code Search:
Jan 08, 2009 | RCA RCR311B Remote Control
Philips model# 27PT31, only turns on manually, no remote
Hello laurenbro, Actually it does make sense if the command processor in the TV set is bad. a way to test this would be to see if the TV will manually turn off and on. If it can, than the problem may be in the command processor IC, also called the input data IC. You will have to take this set to a TV repair shop, and have the look at that section.
Sep 12, 2007 | Televison & Video
Samsung LN32C530 32 in. TV Logo
Jerry Greenberg
Jerry Greenberg
