Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer fills wit wate gos wash cycle but does not drain
SOURCE: Help!! My maytag neptune MAH6700AWW is having trouble.
the fix was simple i just had to lift my drain hose off the floor. it had become disconnected from the back of the washer and was lying on the floor. I didn't realize that by it lying on the floor it didn't provide the proper back pressure to keep the water in while filling the tub. this was the NF error. as for the LE error. i haven't gotten it since i took off my cold water hose connection and ran hot water into it to losen the dirt/rust that was caked into the screen that is located in it. My washer is running like it is brand new again.
Posted on Feb 20, 2008
onthejob5130
  • 640 Answers
SOURCE: Washer quitting on rinse cycle
no cold water ,,lid switch or defective
Posted on Dec 25, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Posted on Jun 11, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
Ge_wdsr2080d5ww started leaking when I attempted to wash a load of laundry.
It is possible that the water has leaked due to overflow as the wate level had exceeded or there was leak from the seal. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
Jul 05, 2012 | GE WDSR2080D Top Load Washer
My washer keeps draining water during the fill cycle. It pumps the water out as fast as the water is going into the tub. This only happens on the normal cycle-other cycles work OK.
it could be the programer at fault or,,,there is a small pipe from the bottom of the tub that gos to a censor at the top of the washer its the over fill censor pull off the pipe from the censor at the top and blow down it if there is any yuck in it this should clear it out and it may then work ok
Oct 17, 2010 | Whirlpool Washing Machines
Washer doesn't drain it just lights up on the drain cycle but nothing happens . wash cycle is fine.
need to open washer and check the DRAIN MOTOR PUMP it could be clogged , usually located at bottom side , small motor wit propeller where the DRAIN HOSE is connected , hope it helps , AJ
Nov 11, 2009 | Computers & Internet
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Kenmore washer spins slow or will not spin
taking that it will wash,,you have a bad transmission,,onthejob
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Jun 09, 2008 | Asko W6021 Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
