Question about Chrysler Vehicle Parts & Accessories
1997 Chrysler cirrus tensioner pulley
How to put on a tensioner pulley and belt
    Sergeant:
    Champion:
  • 248 Answers
If you have never done this before, it would be wise to pick up a service manual from the part store for you vehicle.. this will tell you how and what tools are needed
Posted on Sep 30, 2014
2 Suggested Answers
SOURCE: i do have a 1999 grand marquis w/ belt problem the belt does not have enough tension so i did change a new tensioner abd also a new pulley still have the same problem belt is too loos
If the belt worked properly before then it may have stretched and needs to be replaced. If you recently changed the belt and discovered the slipping problem, you have the worng belt on your car.
Posted on Jan 14, 2014
What does the book say in hours to replace the timing / water pump on a 1997 chysler cirrus 2.5 v6 ? Or in your opinion what's a fair price to have this done by private person coming to the house .
Replacing Chrysler 2.2 and 2.5 liter engine timing belts
www.allpar.com/fix/timing-belt-22.html
Replacing the timing belts on Chrysler and Dodge 2.2 and 2.5 liter ... Then loosen the bolts on the crankshaft pulley and the water pump pulley so they will be ...
HOW TO PUT WATER PUMP ON - 1997 Chrysler Cirrus
repairpal.com > Questions > Chrysler > Cirrus > 1997 Chrysler Cirrus
Jul 4, 2010 - WATER PUMP WANT HOLD WATER LONG AND NOW IS MAKING A ...If you change the water pump,you need to also change the timing belt ...
Timing belt - 1995 Chrysler Cirrus - RepairPal
Nov 24, 2015 | Cars & Trucks
My 1997 chrysler t &c is making a loud clunking noise, steers hard and overheats. Mechanic says it's tension pully. does that sound right
It sounds like it to me. Your van has a serpentine belt which is pulled tightly by the tensioner pulley, hint the name "tension" pulley. If this is defective you will experience the problems/symptoms you have listed, hard steering, over heating, and the clunking,which must be the defective tension pulley. All those problems should resolve immediately after it is replaced. Don't forget to replace the serpentine belt too, for preventative measures. How this helps...
Jul 25, 2014 | 1997 Chrysler Town & Country
What causes the 2 belts to come off the pulleys on the 1996 Cirrus?
they need more tension or they are not aligned properly
Jul 07, 2014 | 1996 Chrysler Cirrus
How to tighten a serpentine belt on 2000 chrysler cirrus
Try this, adjust the belt tension so that the belt is sloppy and then tighten the center bolt. If the pulley is straight that I am going to bet that the belt is stretched or wrong and the tensioner puller is bottomed out which would make it go crooked.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 12, 2012 | 2000 Chrysler Cirrus
How do you get the belt over the pulley when the wrench is interfering with the belt? On a 1997 Town and Country 3.8L.
try putting the belt over the tensioner pulley and remove the belt from another pulley , then release the tension and position belt over final pulley
Jan 16, 2011 | 1997 Chrysler Town & Country
I'm trying to change the serpentine belt on my 1999 cirrus and need help --any suggestions would be appreciated
youll need a 13 &15 wrench undo the pulley and tensioner,dont take pulley all the way off thou,then slip old belt off and put new one on.the pulley has a bolt in the center of it and a little set screw 13 on the side of it towards the front of the car
Oct 11, 2009 | 1999 Chrysler Cirrus
My drive belt on a1997 chrysler sebring is off can you tell me how to put it on.
If this car has a v-6 (2.5). You have to loosen the belt tensioner. It is located along the side of the passengers wheel well. Turn the passengers tire outwards, and kneel down. Look inside the wheel weel, and about the same line of sight as your eyes when you look in there you will see, a bolt, and a pulley, with a bolt in the center of the pulley. Loosen the pulley bolt first, and then loosen the tensioner bolt, Pun on belt careful to watch the routing, and pull pulley tight, with hand, and then tighten the tensinner bolt. Belt should be taught, but not very tight. Then tighten the pulley bolt.
Chuck
Mar 27, 2009 | 1997 Chrysler Sebring
Drive belts
Belt came off 1998 chrysler sebring lxi
you have two belts . put the large belt on first . it goes around crank pulley air conditioning pulley alternator pulley.loosen tension pulley to adjust belt. tension. then you put the other belt on power steering pump pulley and crank pulley. adjust belt tension loosen power steering pivot bolt. that it.
Mar 16, 2009 | 1998 Chrysler Sebring
Drive belt
BELT TENSIONER WILL LOOSEN THE OUTSIDE ONE SO YOU CAN GET TO THE SMALLER ONE
Sep 12, 2008 | 1999 Chrysler Cirrus
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
