Question about Garden
Masport 600st
Can some one give me instructions please on how to clean a carburettor on masport 600 st lawn mower
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 256 Answers
Remove your carb. have a flat clean spot to work. disassemble the carb paying attention as you do to where thing are. once you have remove the float bowl remove the rubber ring from carb or bowl(whichever it stuck to) remove your float being careful not to crush it or damage it. next remove the needle and seat if it didn't come out with the float. spray a quality carb cleaner through any and all ports or holes you can. some are dummy holes so expect some spray back (wear eye protection), blow carb out with compressed air only. no cloth or paper towel. reassemble in opposite order with new parts. make sure your float height is adjusted properly
Posted on Jul 06, 2014
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
Posted on Nov 28, 2010
kel1guy2002
  • 3740 Answers
SOURCE: how do I repair the pull cord on a masport 600
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Posted on Dec 06, 2010
pctech1
  • 1940 Answers
SOURCE: What would cause no spark? the mower is a masport
Your spark plug wire may be damaged, or your magneto may be too weak to generate a spark. You also have a kill switch wired to your magneto, and a condensor. I would start by cleaning the contacts of the magneto and then check the gap between the magneto and the flywheel. The gap between the flywheel and magneto should be .010". I would start by checking the kill switch wire for damage. If any damage is suspected, replace the kill switch. Next, I would have the magneto tested or replaced. Also, check all your ground wires for damage, or loose contacts.
When you are checking for a spark, you should have the spark plug installed in the spark plug wire as normal, but not installed in the engine. The spark plug base should be grounded to the engine while trying to start and checking for a spark. If there is a weak spark, this is probably due to a worn magneto.
Posted on May 24, 2011
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
Looking for a maual for masport maxicut petrol lawn mower
get on the computer and go to yahoo or MSN or google and put in (manauls for masport maxcut lawn mower) or Ebay
Oct 11, 2014 | Garden
What would stop the carbator from work rite
Generall y dust or small grass particles or unclean fuel. remove parts till you get to a stage where you can clean the inside of the carburettor. get a Carburettor fluid from advance auto parts and spray clean the inside of the carburetor. Also check the air filter, if it is dirty clean or replace that. that should fix it, that is the extent of what you can do u'r self. if after this the lawn mower still won't start , drain out all the fuel from the carburettor as well the fuel tank and put in new gas and then try to start it again.
Aug 31, 2014 | Garden
I cannot start my 635 masport mower
check to see if you have spark, fuel delivery and a clean air filter. If you have these then check your timing
My masport 600st lawn mower wont stay running it appears to have a blockage in the fuel line. What action do I need to take to fix problem
you have a sticking float in the carburater you will have to get a carb kit for some carb cleaner any local auto store take off cleanit then let it soak in the cleaner 3 hrs hers the big you need a air compresser to blow air threw the carb little holes and big holes put it back to gather throw out gas install new gas and sea foam injecter cleaner 2 capsfull in the full tank you should be ready togo and have more power to
Apr 19, 2014 | Garden
How do I clear a fuel line blockage on a masport 600st
try spraying some throttle body cleaner into the air intake. Let it sit for few minutes. Then spray in some starter fluid.
Masport 400
Go to youtube On line type step by step assembling masport 400
Oct 24, 2013 | Garden
Looking for a Handbook/Manual for a Morrison 16in.Reel Mower about a 1979 or 1980 model.Can anyone assist.
The mowers are:
Model 400 (3.5 hp Briggs and Stratton)
Model 500 (Honda GX160)
Model 660 (Honda GX160)
I do not have the manual your looking for but the part number for the owners manual is
031796
You should contct these folks to order a manual:
HEAD OFFICE - NEW ZEALAND
Masport (NZ) Ltd
P.O. Box 14-349, Panmure
Auckland 1741
New Zealand
Phone: ( 064 )( 9 ) 571 1200
Fax : ( 064 )( 9 ) 571 5864
Website : www.masport.com
Email : sales@masport.co.nz
PARTS manual is here:
http://www.masport.com/LinkClick.aspx?fileticket=xZ1hKEx%2FYSc%3D&tabid=655&mid=1460
Thanks for choosing Fixya,
Kelly
Jan 05, 2011 | Garden
Masport rota-hoe
try this forum, bruce there seems to be the man to know about ur machinery, he could more than likely help
http://www.outdoorking.com/forum/ubbthreads.php/ubb/showflat/Number/5827
Dec 08, 2007 | Computers & Internet
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
