Question about Brother CS-8150 Computerized Sewing Machine
Brother sewing machine GS3700 stuck in reverse
Australian S
  • 46 Answers
SOURCE: Sewing machine sews only in reverse.
To all the people with this problem. What has happened is the reverse mechanism has stuck, this is often due to not being used for a while or the machine has not been oiled properly, which is hard to do for a user as you virtually have to remove all the covers.
If this particular machine has a screw on cover at the end where the handwheel is, remove it and look inside, you will see the mechanism, what you need to do is push it back out, then oil it but make sure you work the reverse button in and out while you oil it and check it works freely, then just refit the end cover.
Posted on Jul 02, 2009
mohammed387
  • 1952 Answers
SOURCE: lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Posted on Jul 26, 2009
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
Posted on Aug 03, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
  • 96 Answers
SOURCE: brother sewing machine sews in reverse only
you will need to have it serviced sounds like an internal issue with the dial
Posted on Dec 13, 2009
I have a Brother sewing machine,model XL 6562, unsure of age, it's older. Today it only sews in reverse, cannot make it go forward. Help!!
well reverse button must be stuck. Try turning wheel to move forward and setting the stitch, like to zigzag. Oil it good, old machines get "thirsty".
Aug 01, 2017 | Brother Sewing Machines
Machine will only go in reverse, suggestion to make it sew forward
What Brother machine do you have, on mine I have to push a button on the machine to go in reverse, sounds like yours could be stuck in that position. If you have the manual see if there's a section on help problems. Hope you get it working soon
Feb 11, 2015 | Brother Sewing Machines
Brother sewing machine stuck reverse
Take to sew and vac! LOL. Unfortunately, this requires a machine repair individual to inspect. So (LOL) stop delaying and take that sad little machine to a sewing machine doctor. :) Good luck- it will be back in shape soon.
Mar 03, 2014 | Sewing Machines
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Machine stuck in reverse will not go forward
With these very cheaply made Brother models, unfortunately it is going to need to go for repair, if you try to open the casing you WILL break something.
Oct 23, 2011 | Brother XL-6562 Mechanical Sewing Machine
I have my Mother's Brother XL3750, no book or accessories. It will sew in reverse only. I don't even know where the reverse button is. The only thing that I have tried is the big lever front...
you can download a manual for your machine from the Brother website,
link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000452/bm2736xl26i35i375ug04enes.pdf
Reverse is the big lever in front but it should be sprung so you need to hold it down to reverse; if your machine is only sewing backwards, this lever might be stuck or locked into position. Check out page 25 and 26 in the manual for specific info.
Sep 10, 2011 | Brother XL3750 Mechanical Sewing Machine
The push down button for reverse is stuck and will not reverse. How can I fix this?
Just buy a replacement push button from Brother
Sewing Machine dealer.
Nov 08, 2009 | Brother LS2020 Sewing Machine
Brother Machine!
The reverse mechanism is stuck. The machine has to be completely disassembled to get to the problem. It is usually not a big deal to get it "unstuck" but taking it apart can be a pain. A good machine tech. can do it easily or you can give it a shot. Just look what the reverse lever actuates and see how it is stuck in the reverse position. It is usually the stitch length/reverse block.
Aug 06, 2009 | Brother XR-65t Mechanical Sewing Machine
Lever is stuck in reverse
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Brother CS-8150 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
