Question about LG Flatron L1750S 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
When I start the computer, the screen comes up for about 10 seconds, then goes blank, but the blue light stays on. When I turn off the monitor and turn it back on, the screen displays again for about 5-10 seconds, then goes blank again. The underlying program continues to run. Regbooting the computer hs no effect.
  • robert_wi519 Jun 19, 2009
    Thank you! I will try this when I get home tonight. By the way, my monitor, which is a Flatron 15", is about 3-4 years old. Does that make a difference re trying to fix it vs. just replacing it? Is it getting to the point where I'm likely to start seeing other problems cropping up soon?
  • 1,684 Answers
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
  • Buddy Mcsparrin Jun 19, 2009
    After replacing the bad capacitors you should have a few years left on the monitor. Since it is a 15" lcd you may want to replace it any way just to get a bigger screen. Let me know if you need any help when you check the monitor.
    Buddy
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Computer was on, screensaver is from my photo file - it was running. I moved the mouse to get back to the screen I had previously been on, walked away for a minute, came back, the screen was black. ...
Windows 8 especially and sometime Windows 10 may have a black screen during an update for over 15 minutes with no indication that anything is happening.
Try complete power down by holding the power key for 10 full seconds. Consider unplugging power for a few seconds after that as well.
Re-connect power, press power button to turn on the computer then if the screen goes blank, give it a half hour before looking for another solution... it may come back to you.
Nov 06, 2017 | Sharp LL T19D1-B (Black) 19" LCD Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Cinema Screen goes Blank intermittently
my tv, s name is SHARP 14inches cinema screen keeps blanking.
since threedays has any solution .
Aug 19, 2009 | Computers & Internet
Sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Jan 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
LG Flatron L1750S 17" LCD Monitor Logo
756 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
