Question about KitchenAid Khms1850sss1 Microwave Ovens
Replace humidity sensor khms1850sss-1 - KitchenAid Khms1850sss1 Microwave Ovens
When trying to Popcorn the touch pad is dead and comes up on the display F4?
Its you humidity sensor causing the code:
F4 - Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds, it says to replace the sensor.
You can order it in http://www.repairclinic.com/PartDetail/Sensor-or-Thermistor/253789
Hope this helps.
Aug 11, 2011 | Microwave Ovens
Looking for a place to purchase lamps in my microwave hood combo: Model KHMS1850SSS-2 Thank you so much.
We have those in stock part # AP4358902 Enter your model # at www.appliancehelponline.com All parts come with installation instructions
Nov 04, 2010 | Microwave Ovens
Error Message F-5
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor.
Oct 25, 2010 | GE JVM1650 1000 Watts Microwave Oven
F5 error code
F4
or
Sep 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I AM VERY DISAPPOINTED IN GE 'S HELP WHERE THEY WANT TO CHARGE 9.99 DOLLARS FOR HELP ON MY MICROWAVE WHICH IS OUT OF WARRANTY. IT IS ALMOST 2 YEARS OLD
Hi AGAIN DIBARTRK
Now that you have indicated the make of your oven....... the fault codes for GE microwaves are as follows. I have given you all of them for you future reference. :)
F1 - ( open thermal sensor ), will occur below 190�F of cavity temperature within 15 minutes of starting convection, combination or roast cook.
F2 - ( shorted thermal sensor ), will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
Note: it will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted/open.
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
F4 ( open humidity sensor ), will occur if humidity sensor is detected as being open continuously over 5 seconds.
F5 - ( shorted humidity sensor ), will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Note: It will will take a minimum of 15 seconds after the magnetron is energized before the F4 or F5 code will be displayed if the humidity sensor is shorted/open. Also the unit must be plugged into a 120 volt outlet for at least 5 minutes before sensor is checked, this also applies after the humidity sensor has been changed. Before checking operation of new sensor allow init to be plugged in for at least 5 minutes.
F6 - ( shorted temperature probe ), will occur if temperature probe is detected as being open or not plugged into the receptacle. If probe is plugged in and "ProbE" is on display, check probe for continuity with ohm meter.
they are all different for different brands... It is much easier to get a solution from FixYa you actually tell us what sort of equipment you are having trouble with. :) Do I get a FixYa rating now... :)
regards
robotek
May 06, 2008 | Microwave Ovens
Humidity sensor
replace the humidity sensor. is it a GE?
Dec 30, 2007 | Microwave Ovens
KitchenAid Khms1850sss1 Microwave Ovens Logo
22 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
