Question about General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni...
Clock runs too fast, how to adjust - General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni...
Set the clock on Eclipse CD3414? step by Step
Turn [SEL] button to select CLOCK ADJ.
Press the [SEL] button. The clock adjustment mode is activated. Turn [SEL] button to display the item to be selected for adjustment. Hours, minutes or exact hour will be switched each time the button is turned.
Press the [SEEK /FAST ] button. [SEEK ] button: Turns the time forward. [FAST ] button: Turns the time back. To set the clock to 0 minutes, 0 seconds (an exact hour), press the [SEEK /FAST ] button.
For example: At 3:29: Pressing the [SEEK /FAST ] button returns to 3:00. At 3:30: Pressing the [SEEK /FAST ] button advances to 4:00.
Press the [RTN] button. At this time, other adjustments can also be made in Function Mode. 6 Press the [FUNC] button to exit Function Mode.
Also, you can read the manual here:
http://www.eclipse-web.com/us/download/manual/manual/pdf/CD3414(1-1455A).pdf
Jan 27, 2017 | Cars & Trucks
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
Polaris grandfather clock runs slow need to adjust time up
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Nov 17, 2012 | Watches
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
3 Turn [SEL] button to display the item to be selected for
adjustment.
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
I have an older large wall clock - model 88100. It is 2 minutes fast. I've replaced the battery but it still runs 2 minutes fast. Always the same amount. Any ideas? With an atomic clock it should be right...
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
Jan 22, 2010 | Watches
General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni... Logo
Top General Time Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a General Time Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
