Same problem for me.. hope anyone can solve this!!
Battery doesnt charge.. red light is flashing the whole time.. camera is dead when battery is in charger more then 1 night.. hope someone can solve this problem..
i think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
kindly leave the battery for long duration in charging position let the red light blink and then see after like 16 hours or 24 hours if it works and charge otherwise change the battery with the same specs , and next time when u leave battery for long duration likea month or weeks charge it to full or half so it can hold some power to re charge again , ur battery is in Coma state nearly dead so it might come back or not
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery. ylu1 writes: I had the same problem as this. what i did was... i kept putting the battery on the charger then took it off as soon as the red light came on. i did this about 6 times. doing this puts a bit of charge in the battery each time before the charger starts to flash. after the battery as got enough charge in it it can start to charge. hope this helps.
I found this while trying to solve my very similar problem. It worked for me after about 7 times. Other people wrote that it wook them 20 times... good luck!
i would replace the charger 1st seeing as its the cheapest thing to do. if that doesnt solve the problem. return the charger to where ever you got it from and purchase a new battery.
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
I tried charging 3 AAA batteries on my 15 minute energizer charger and the light kept on flashing. Not sure what to do or who to call. Anyone have their #?
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
