Question about Polaris 9400 Sport 4WD Robotic Inground Pool Cleaner
Polaris 9400 does not respond when start button is pushed or any button for that matter.
It seems to be completely dead. No flashing lights or any lights at all. Has been working just fine. Plugged it in to two different outlets.
What causes an error code 10?
Hi Daryl, I searched "polaris pool cleaner error codes". The first three or four hits all look useful. Give them a try.
Jul 11, 2015 | Polaris 9400 Sport 4-Wheel Drive Robotic...
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Power button not responding
Customer calls IRobot Customer Service (No Parts or Service Literature is available)
Customer Service at 877-855-8593
Nov 06, 2009 | iRobot Roomba 560 Robotic Vacuum
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
No water from my Bissell
I AM BISSELL WARRENTY DEALER, AND MOST COMMON PROBLEM WITH THESE UNITS ARE CLOGGS IN THE LINES AFTER THE HEATER OR IN THE HEATER THEM SELFS VERY DIFFICULT TO GET INTO. THE PUMP IS A DIRECT DRIVE WITH NO BELT AND I HAVE NEVER HAD TO REPLACE ONE NOT TO SAY ITS NOT THE PROBLEM BUT UNLIKELY IF AT ALL POSSIBLE TRY TO GET SOME FLOW AND TRY RUNNING SOME SORT OF LIME AWAY CLEANER INTO SYSTEM AND LET SIT THIS WILL HELP PREVENT CLOGGS AND POSSIBLY CLEAR CLOG OTHER WISE YOU WILL HAVE TO DISSASSEMBLY MACHINE AND CLEAR HEATER AND LINES MANUALLY. IF YOU GET WATER TO ATTACHMENT HOSE BUT NOT NOZZLE YOU MAY CHECK THE RED TIPS FOR CLOGGS. THESE CAN BE REMOVED WITH OUT TAKING THE MACHINE APART.
Mar 30, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Polaris 9400 Sport 4WD Robotic Inground Pool Cleaner Logo
27 people viewed this question
Top Polaris Vacuums Experts
JoeVacs
Are you a Polaris Vacuum Expert? Answer questions, earn points and help others
