Question about Danby DWM17WDB
Danby portable washer drain valve won't close DWM17WDB
My washing machine will start but then there will be a loud beep, which makes it stop and it will not drain properly or even spin. What should I do?? Thanks so much!
sounds to me that there might be a problem in the "Tilt" sensor this sensor stops the machine if it detects a rocking machine thats out of ballance , so it wont tip over , ck level of machine with a bubble level
Jan 05, 2015 | Danby DWM17WDB
I need a danby hose connection drain plug
From what I understand it has a hose connection for the drain. If you go to one of the big box stores they sell caps that will fit the end of a garden hose or sprinkler hose and close it off.
Feb 26, 2014 | Dehumidifiers
Danby ddr5511r owner manual
Yess the DDR5511R has the drain hose connection inside the compartment where the water bucket sits. It is at the top right corner. You have to remove the water drawer to see it. At the right side of the unit (on the outside) is a small "door" that flips up so that you can feed a hose throught to the threaded outet inside. The drain hose is not supplied with this unit.
Mar 26, 2012 | Danby Dehumidifiers
What is the drain size to run in copper for Zenith ZD300 dehumidifier. The inspector will not let us use a garden hose for drain as per you instructions. Fire hazard, we have to run a copper drain. What...
Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
Sep 19, 2011 | Whirlpool Dehumidifiers
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Need owners manual for Danby DPAC10060(R)
Gwen, here is a link to the Owner's Manual for your Danby, Model DPAC10060, Portable Air Conditioner. You can download and print the manual for future reference.
http://pritchard.dyndns.org/mediawiki/images/Danby_DPAC10071_EFOM.pdf
Hope this helped you.
Jun 30, 2011 | Danby DDR2509EE Dehumidifier
Stopped discharging water out the drain tube. on inspection the tubes plastic flange that holds the flat washer (Rubber) has severed from the tube. Where can I order a new Danby tube like this one ?
Try your local big box hardware, they probably have something that will solve you problem. If not then contact one of the many appliance parts distributors and get the part from them.
Good Luck,
Gilshultz
Dec 01, 2009 | Danby Dehumidifiers
Danby DWM17WDB Logo
29 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
