Question about Initial IDM-1731 Portable DVD Player with Screen
Sed one time an now only powers up with with only green lite for showing charged but doesn't do nothing, no sound no monitor, but monitor will flash when on an off switch is toggled back an forth. do
Is an inital idm-1733 7" monitor
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
Wont re-charge,when attempting to,red light flashes once then nothing,same when turning on,green light flashes once,then nothing
Sounds like the battery is dead. Sent it in for repair or buy a new battery if possible. Check google for solutions.
Nov 10, 2009 | Nintendo DS Lite Console
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
Black screen green lite on/flash right green lite off
The problem on your monitor is a bad power supply. We you can solder you should be able to repair it. If you check our site at :
www.ccl-la.com/badcaps.htm We have a monitor repair section with dis-assembly guides and repair procedures. I will post a Hanns-g guide tonight. This will show how to open and repair the monitor. We also have a repair parts kit available. If you don't want to do the repair yourself then we can do it for you, just email me if you have questions or wan tus to do the repair for ou.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Aug 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Samsung 930BF Problem
try the monitor on a friends computer or family menbers computer first as it may be your grafic card at fault.
Jun 01, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Initial IDM-1731 Portable DVD Player with Screen Logo
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
