Question about XO Vision Car Audio & Video
How to connect steering wheel controls from honda crv 2008 to a non factory audio equipment
SOURCE: avic-d3 to steering wheel controls
you need an interface, which then plugs into the back of the avic-d3...
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Steering%20Wheel%20Interface
you might get charged up the *** to install it, i recommend if you have any friends who know how to install to help u out... havent even got around to installing mine yet cuz installers were telling me it would be 'custom job' cuz they haven't installed it before, and then you get the hourly rate n they can basically rape u if they want to..
cheers!
Posted on Jul 15, 2008
SOURCE: 2002 Honda Accord EX V6 cruise control failure
http://www.handa-accessories.com/accord/accswc.jpg
So after you push the button and then press the set button in the steering wheel it does not get into cruise control ? It sounds like a minor electrical problem. If you have warranty still I think the dealership should fix it for free.
Sorry i have not been able to help you.
Posted on Jan 22, 2009
SOURCE: 2008 Honda CRV ES L
Have a 2007 Crv ex auto first in Ireland was pulling to left on day we pick up car.Dealer is a friend so called Honda Car was brought back 4 times changed tyers etc no fix.Dealer had 6 new cars with same problem so Honda sent engineers from japan to find fix.In the end it was a camber problem ie roads in different country's have a set camber to let water flow off.Crv has no adjustment for this so new shocks in front an everything ok now .Hope this helps?
Posted on Mar 21, 2009
SOURCE: 2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Posted on Jun 26, 2009
snowbo13
SOURCE: Honda-crv 2008, When to change the oil.
Honda say thats not true and to wait until the car tells you when to change it. I have a 2008 CRV and you should and can wait till the oil say 15%! We took ours in after a long road trip for our first oil change. We had over 5K and the oil said 65%. The guy said that we did not need to bring it in. We still had change it while it was their but the car goes around 8-9 K on a oil change. A little wrench will come on and the oil life % will come on when it reach15% and will come on every time you start the car till you get it changed.
Posted on Sep 10, 2009
Where is diagnostic plug on 1998 crv
the obd2 plug of HONDA CRV is below the steering wheel. please check. any other questions, you can feel free to contact the tech support 2013 Multi Diag
Sep 10, 2013 | Hayden-Harnett 1997-2001 Honda CRV Engine...
Honda odyssey steering wheel volume control fix
it sounds like you may have an intermittent connection/ broken wire in the steering column, or contacts to wheel. possibly needs a cleaning. YOU MUST BE AWARE OF PROPER PROCEDURES, AS YOU CAN ACCIDENTALLY TRIGGER THE AIR BAG, RESULTING IN INJURY AND/OR DEATH.
Sep 02, 2012 | Honda Car Audio & Video
Factory radio in 2010 honda crv
You will have to pull out the head unit and see if there is a blue remote wire for am and rca audio output jacks that go to amp. I highly doubt it. Usually you have to get an aftermarket deck
Jul 27, 2010 | Kicker Car Audio & Video
I have a 2005 honda crv, after changing the steering rack the cruise control is not working
There is a cable reel (clock spring) in the steering column. If it was not centered when you put in the rack than it probably broke.... Is the SRS light on too? This cable reel allows electrical connection to the air bag and the cruise control switch (mounted to the steering wheel), so you can turn the wheel. Its operating range is two and a half turns from center in both direction. When you disconnect the steering coupler from the rack the steering wheel moves, now the cable reel is not centered. If you put it back on in this position and turn the steering wheel fully to one side the cable reel breaks. That could be what happened, however the cable reel is very expensive so make sure that's it before replacing. I recommend performing an input test on the cruise control unit to confirm.
Nov 09, 2009 | 2005 Honda CR-V
I need a radio/cd, that would work with my steering wheel control
im sorry but i must be blunt the people who installed your deck were lazy instead look up factory wheel control module on google there is a system that (as long as the deck has any type of remote) allows you to hook this up run a small wire with a out put laser to the front of your deck acting as a remote control if this infact is not the case use crutchfield.com enter in your car information look threw the decks when you find one you like look in eccesorys if its not an option it wont be there :) honestly the jvd avx 820 is amazing for the price check it out it will work with your controls
Sep 24, 2009 | Blaupunkt Alicante CD32 CD Player
2009 Honda CRV Problem
how can you turn the steering wheel to lock position while in drive? did it actually click in lock positon while in drive?
Sep 16, 2009 | Honda CR-V Cars & Trucks
Solution:
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
What fuse # controls the in cabin fans on a 2004 Honda CRV?
The fuse box is located under the steering wheel to the right. A diagram on the back of the removable door should show you which fuse to check. You will likely need a pair of needle nose pliers to reach/pull the the fuses, they're recessed beyond the opening.
Jun 30, 2008 | 2004 Honda CR-V
Car Audio & Video Logo
32 people viewed this question
Top XO Vision Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
mega_mind
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
