Question about Hoover Spot Scrubber Multi Surface Cleaner Model FH10025, 1 ea
Hoover spot scrubber wont dispense water - Hoover Spot Scrubber Multi Surface Cleaner Model FH10025, 1 ea
5 Suggested Answers
  • 8 Answers
SOURCE: won't dispense cleaning solution
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Posted on Aug 29, 2008
SOURCE: hoover steam scrub steam vac
The recovery tank also has a clear plastic piece in the front that is suppose to be snapped into place to make sure its in place pull on it in the direction of the handle of the steam cleaner if it snaps then that was the problem it got out of place
Posted on Feb 11, 2010
  • 13 Answers
SOURCE: my hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
Posted on May 25, 2010
  • 240 Answers
SOURCE: hoover silver carpet scrubber wont
There are two common situations that can cause lack of pick-up. First is that the lid is not properly attached to the recovery tank. Make sure it is latched in back and snapped in place in front. The second common problem is that the duct on the front of the dirty water tank is missing. There is a plastic duct about the size of a slice of sandwich bread which slides into the front of the tank, and is removed when the hose is in use. A less common problem is that the large round rubber seal that the tank sits on has fallen off the suction tube on the motor cover.
Posted on Jan 29, 2011
Dirt devil spot scrubber not picking up
Hi there! There are a few reasons why your spot scrubber may not be picking up. Your dirty water tank may not be seated properly or the filter may be dirty Please try these steps.
1. Check the filter located on top of the dirty water tank. If dirty, rinse with water.
2. Check that the pour spout cap on dirty water tank is plugged.
3. Replace the dirty water tank. Make sure the dirty water tank is flush to the cleaner and seated properly.
4. Clean the nozzle of any hair or debris.
Hope this helps! For further assistance please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jul 03, 2014 | Dirt Devil SE2800 Spot Scrubber Handheld...
Hoover spot scrubber sprayer not working well.
you can replace both tubes if it helps or you can check for blockages and check the pump off the video below
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY
Oct 31, 2012 | Tti Vacuums
Hoover silver carpet scrubber wont **** up water . did the obvious checks
Jan 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes don't turn. It runs and dispenses shampoo and water and sucks it up but the brushes stand still.I cleaned them and filter etc still doesn't work.
There is a plastic shaft on the back of the block brush (spin scrubbers), these wear out or break. You may need to replace the block brush. Or if the shaft is not broken it could also be the Turbine Gear. This is what the block brush shaft goes into. You can get access to it by taking off the hood. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F72XX Link
http://www.usavacuum.com/Hoover-Steamvac-s/110.htm
Jan 23, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
Hoover steamscrubber
I had the same problem. Fixed it by taking the machine apart and lubricating the bearing inside the turo tunnell. It's a pain, but not impossible if I could do you can. You must start by taking off the cover. Don't forget the scvrews on the front by the water vacuum. I used WD-49 and white grease so far so good. The turbo tunnel will come out by itself.
Dec 30, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Spot Scrubber Multi Surface Cleaner Model FH10025, 1 ea Logo
271 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
