Question about OKI C5150n Led Printer
I have a oki 9600 Fatal error 917 - OKI C5150n Led Printer
  • 95 Answers
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Posted on Jun 22, 2009
  • Mike Dotson Jun 22, 2009
    It can be ordered from an Oki dealer.
    New Friend:
Power off/on917:Fatal Error
This is the message I'm getting on my Oki 9650 printer. I've turned everything off, unpluged, then started again. Aany ideas as to what might be causing this or better, how to fix it?
Posted on Nov 30, 2012
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
929 fatal error on my oki 9600 printer
This is a very unusual error. 929 refers to the waste toner motor not running properly. Remove the waste toner bottle and put a hoover to the outlet to the bottle in case the toner is hard and blocking the exit of toner into the bottle.
Jun 30, 2011 | OKI C9600hdn Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Jan 07, 2009 | OKI C9600hdn Laser Printer
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C5150n Led Printer Logo
1,743 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
