Question about Troy Bilt 5.5hp Self Propelled Mower
Troy bilt 12AG836E711 drive cable install
949-04265a
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
  • 68 Answers
SOURCE: lawn mower
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Posted on Apr 26, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
Troy Bilt Lawn Mower how to fit carburettor cable
Troy Bilt has a great website but you need to find your model number to use it.
Lawn Care Products Lawn Care Equipment from Troy Bilt
Sep 14, 2014 | Garden
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What are the troy bilt 618-04378 transmission parts?
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AG836E711/1307/1500600&shdMod=12AG836E711
Jul 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My self propelled troy bilt mower will not propell. i can lift it off the ground and the wheels turn. i changed the belt this did not help. can anyone tell me if the model 12ag836e711 have the recall for...
according to the troy bilt site there ar no recalls on any lawn mowers.
here's the link
http://www.troybilt.com/webapp/wcs/stores/servlet/DisplayContentView?langId=-1&storeId=10001&catalogId=14102&pageName=siteFooter/productRecalls/productRecalls.html
Jul 31, 2009 | Garden
Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Jul 27, 2009 | 2005 Ford Focus
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt 5.5hp Self Propelled Mower Logo
26 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
