Question about Electric Mobility Health & Beauty
Oil leaking from tiller control column - Electric Mobility Health & Beauty
Troybilt tiller, rough,grinding noise when tines engaged
make sure there is nothing caught in them rubbing the shroud. check to be sure there is oil or lube in the drive transmission. if the oil leaks out it will make a grinding noise.
Jul 09, 2016 | Garden
Why is oil leaking from cylinder
-Oil is over fill.
Good luck
Mai
Jun 09, 2014 | Mantis 4-Cycle Tiller
Why is my exhaust leaking oil and blowing out grayish color smoke
Your piston rings are worn to the point that oil is getting into the cylinder and some is being ejected through the exhaust and some of the oil is being burned causing the grayish smoke.
May 07, 2012 | Troy-Bilt Super Bronco CRT Garden Tiller
Oil leaks out of shaft
hello, you have a bad axle seal that needs replacing,replace or keep putting in gear oil,
Feb 09, 2012 | King Kutter Ii Gear Driven Rotary Tiller...
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
May 30, 2009 | Mantis 4-Cycle Tiller
Mantis gx22: oil leaking out soaking air cleaner, quits running..
i hate to tell you but it sounds like the motor is wore out
May 05, 2009 | Mantis 4-Cycle Tiller
Too hard to crank, the rope is wrond too tight.
you may want to check the oil level, some units can leak gas through the carb and into the cylinder. thus raising your oil level and making it hard to turn over.
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Health & Beauty Logo
24 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
