Question about Whirlpool LER5636P Electric Dryer
Removed broken heating element on Whirlpool electric dryer...forgot to map wires for new element. Attached wires where I thoght they shold have gone. Dryer works but element didn't shut off after cycle and chassis became extremely hot. Unplugged unit.
  • 3 more comments
  • rdeberardis Jun 19, 2009
    I need to see a diagram of the wire connections on the heating element and identify which wires attach to which terminals.
    There are just two red wires that need to be connected.
    I don't really want to try to attach the wires on different terminals in case of short circuit or fry the element or thermostat. Isn't there a schematic showing the wire mapping?
    If a diagram is not available, can you describe which wire goes on what terminal?
    Thanks
    Two red wires coming out the back of the machine at the bottom and to the left of the heating element assembly. Heating element connection has two prongs opposite each other, another half way up the post and then a fourth at the end of the post.
    Hope this helps
    Hope this helps
    President:
  • 1,197 Answers
I found one for my Whirlpool dryer inside! It was in a clear plasticbag taped to inside of front cover, I cam across it whilst I had therear panel off.
Maybe take off front/rear panel after unplugging, you may find one inside...
if that doesn help..... check out the diagrams in the below links
http://www.appliance-parts-warehouse.com/whirlpool-parts/model_view_cats.cfm?id=21289
http://i160.photobucket.com/albums/t200/Zenzoidman/Dryers/dryer.jpg
if ur talking about the thermal cutoff wiring...... the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
The two wires from the dryer are routed in series with the thermal fuse, high limit thermostat and heating element.
When the dryer gets poor venting, the thermal limit is supposed to open up first protecting the thermal fuse and heater from burning up, thermal limit opens at 350 degrees, fuse at 250 degrees.
Also, the thermal limit is designed to stay open for a long enough period to let things cool down before it closes again.
See also a wiring diagram
http://www.tpub.com/content/clothingandindividualequipment/TM-10-3510-209-24/css/TM-10-3510-209-24_29.htm
if u feel i ve been of help to u...... kindly rate my service..... as experts ur rating helps us do our work better!!!!!
good luck
Posted on Jun 19, 2009
U just need to map wires properly again. I think the problem is just related to wrong mapping.
try something else in mapping. hope it will help
  • Anonymous Jun 19, 2009
    Actually its very difficult to say proper mapping without knowing the diagram.
    I would not suggest mapping without seeing the actual prdouct. it may have the risk of damaging the appliance. i would suggest to use an electrician help in real.
  • 3,230 Answers
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected to the dryer case. However, it is useless if the wall receptacle does not have a separate ground slot. In that case, you'll have to do the very simple procedure of converting a 4-wire dryer to a 3-wire setup.
Steps
1. Identify the type of plug that you will need by looking at the "slot pattern" of the receptacle on the wall. You'll need to buy a new power cord/plug from an appliance or hardware store (~$12-$15).
2. The new cord (at the dryer end) will have 3 wires only, no ground wire. The center wire of this cable is the neutral wire and the outer wires are hot live wires. The hot wires connect to the outer 2 connections the power terminal block of the dryer, does not matter which is which as long as one hot is connected to each of the outer terminal connectors. (each outer wire is 110-120 volts which, when added, gives you the 220-240 volts.)
3. The center wire (neutral wire) of the cable goes to the center connector. Since in this case the neutral serves as a neutral and a ground connection, a jumper band (ground strap) is also connected to the center terminal and to the frame of the dryer. A green wire could also be used to connect the center connector to the frame of the dryer.
4. If the dryer cord does have colored wires, white is the neutral wire to the center connector, the red and black wires are the hot live wires which connect to the 2 outer connections of the dryer terminal block, don't forget the ground strap or green wire jumper from the center connector to the dryer frame.
Tips
1. A good resource is this site: http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
2. Tighten the wire clips really well, but don't break them off!
Warnings
1. Always make sure any electrical appliance is UNPLUGGED before working on it!
2. These instructions only apply to a centre-tapped 120/240V supply as found in the US and Canada; do NOT use them in other configurations. In particular, using neutral as ground will prevent ELCBs (earth leakage circuit breakers) or RCDs (residual current devices) from operating and hence present an electrocution hazard.
Good Luck
Thanks
I am trying to replace heating element. my model has 1 wire coming from the bottom to the element. all videos I have seen show two wires. I am confused...
Tim, Could not find your model, look at attached video and see which wire you are not locating. maybe it fell off or is stuck in the body some were.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Google search your make and model# manual.
How To Replace Heating Element Whirlpool Dryer Repair 279838
Dryer Heating Element part 8544771 How To Replace
May 26, 2016 | Whirlpool LEQ9858L Electric Dryer
Whirlpool GEW9200L Electric Dryer won't heat up
The heating element can fail open. Curious that Whirlpool did not mention that possibility.
Jan 25, 2018 | Whirlpool GEW9200L Electric Dryer
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
We took our heating element out of our dryer and didn't mark the wires. Is there somewhere I can download a map of where the wires go? It's a Crosley heavy duty giant capacity.
How many wires do you have? If only two, the heater element doesn't care which wire is attached since it is being fed with AC current there is no polarity to it.
Oct 29, 2009 | Crosley CDE6000 Electric Dryer
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
No heat from dryer
It is most likely the heating element. If you would like to access the element, just take the 3 screws out of the bottom of the kick plate below the door and you will see the element in a canister. There should be a screw on the side of the canister that holds the element in. Remove this screw and pull wires off the element, after you have noted where the wires to the element are properly placed. Then proceed to pull the element straight out of the canister. Inspect the wire coils for breakage, If you find a broken coil wire, replace the element. If you do not find a broken coil wire then proceed to checking the high limit cut off thermals located on the side of the canister for continuity. If you find one of the thermals not to have continuity, replace both thermals. They come in a package together as one kit. Hope this helps. Dave
Mar 30, 2009 | Whirlpool LER5636P Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
No Power
look for an "open" thermostat either on the heater can, or a thermal fuse has gone bad, probably shorted out when the element broke.
May 13, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
