Question about Traulsen Reach in Freezer - G12010
Unit ice up - Traulsen Reach in Freezer - G12010
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
Oct 23, 2017 | Refrigerators
My Icemaker won't keep the ice once it makes it
What make and model of ice maker do you have?
Is the unit making ice? If so, about how much?
Most commercial bin type ice makers are not engineered to maintain the ice once it drops into the bin. Older ice is intended to melt and the water should drain out of the bin as new ice is deposited on top.
It may be that you are consuming ice at a rate greater than the unit is designed to produce ice, or that the unit is not set to the highest ice production rate (if adjustable).
Alternatively, if the inside of the bin is hot (warm) you may have another problem with the unit (e.g., gasket leak). Was the unit previously working? If so, are you aware of any events that took place just prior to the change?
Some units have a defrost or a cleaning mode, which will actually generate heat inside the unit. Make sure the unit is set to the correct mode.
Feb 12, 2014 | Manitowoc QM30 Under Counter Ice Maker
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice dispenser will not work
first check ice making unit is filled with ice, if empty sounds like ice maker water inlet valve not operating.if ice bath full then problem with ice making unit itself,either heater, ice harvest switch or geared paddle motor faulty.either way would recommend changing out the whole unit, alot less fuss and not too expensive
Feb 27, 2010 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Freezer is icing up. Unit is about 2 yrs old
You need to check out the back of the freezer. At the current status, it may be locked with ice. Have it defrosted or just have it melted away. Clean the coils and the entire unit. Either the drains were blocked by food debris or dirt causing water to accumulate and ice to form or the thermistor has been iced or is faulty or too much ice accumulated in the unit's coils.
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice is being made, but the unit is on and water is hooked-up.
Depending on the model you have. Your unit will run until the thermostat is satisfied. The it calls for water. Then the next batch will have ice.If its a clear ice then the unit should start to make ice right away. However it will take 5 cycles to get the ice the right size. What model is it?
Jun 23, 2009 | U-Line Icemaker
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
NO ICE (ATLEAST NOT WHERE IT SHOULD BE)
Try to defrost the unit, after defrosting restart the unit and monitor. If ice formation still exist then unit a qualified technician. May be your unit has leak and under charge or need to be reprocess.
Jan 07, 2008 | Frigidaire FRS3R5EMB Side by Side...
Air conditioner freezing up
Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
Jul 17, 2007 | Goldstar R5050 Air Conditioner
Traulsen Reach in Freezer - G12010 Logo
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
