Question about Jensen JTA460 Turntable
Needle replacement How to replace needle on Jensen JTA-460. Step by step instructions please.
2 Suggested Answers
  • 3 Answers
SOURCE: Just received my Jensen JTA-460
There is a speed selector directly under the needle arm.
Posted on Sep 19, 2011
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Can my turntable be adjusted
Jody, the arm the needle is on, usually adjustable with a dial on the end that can lighten, or put more weight on needle to help it track better on records. Other then that, the belts normally are changed to address slow speed issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JTA 220 Instruction Manual Page 2
http://audio.manualsonline.com/manuals/mfg/jensen/jta220.html
How To Calibrate Your Turntable For the Best Possible Sound
How to Adjust Tracking Force
Apr 09, 2016 | Jensen Jta-220 3-speed Stereo Turntable...
I wrongly plug jensen jta 460 turntable to 220volt power outlet. Can it be repaired? What is the dc out put of th?s power adapter? Can I change this original adaptor with 220volt ac dc adaptor?
Depends on how big it is, probably not, either the transformer coils might be burnt, causing a short (did you see or smell magic smoke?), or the diodes might be burnt (did you see or smell magic smoke?) or capacitors might be blown (did you see or smell magic smoke?)
As far as a different adaptor, see my response to your other question:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=25839291
Aug 27, 2015 | Computers & Internet
Needle replacement for Jenson JTA 460 turntable
Hi, stylus is Sharp STY146. Cheers John, Stylus City
May 16, 2014 | Audio Players & Recorders
Jensen JTA-460 will not power ON?
It may start when the tonearm is lifted. If not, the turntable may have failed
Dec 26, 2012 | Jensen JTA460 Turntable
I need it now jensen jt a 460 turn table manual
Tech Help call 1800 686 079 Mon -Fri 9am to 5pm I have a JTA 380 Manual ? similar spec's.
Mar 11, 2012 | Jensen JTA460 Turntable
How can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
Feb 13, 2012 | Jensen JTA460 Turntable
Please tell me step by step how to download songs to my Jensen MP3 player. Thanks. Judy Conkle timwjudy@yahoo.com
Hello
OK, at the link below you will be able to get step by step instructions on how to transfer music to your MP3 player from your computer.
Click HERE to navigate to the page.
Please let me know if this was not sufficient, so we can try a different method.
Kind regards
Andrea
Aug 13, 2010 | Jensen Audio Players & Recorders
Help replacing a starter on 89 F350 460 4x4?
chilton makes a great book that will shoe you step by step details
Jan 03, 2010 | 1989 Ford F 350
Jensen JTA460 Turntable Logo
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
