Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Sir, I am in India with Electrolux Dishwasher. Machines drainage pump is leaking. It has be replacer. Could you help me where to get it in Gujarat India. Regards Mrs. Malti Baad
  • LG Master
  • 528 Answers
Go to sears part web site :) good luck
Posted on Jan 01, 2010
F21 fault code on Electrolux dishwasher. What does it mean and how can i clear it??
Electrolux Dishwasher Error Code 01
Fault Condition: Water Leak Is Detected (Sensor under the dishwasher detected a leak)
Repair or Check: Remove power to the dishwasher. Check hoses, pumps, and tub to find the leak. Replace any parts leaking.
Parts Required: Drain Hose - Drain Pump - Recirculation Pump
Electrolux Dishwasher Error Code 02
Fault Condition: Thermistor Sensor Fail
Repair or Check: Remove power power to the dishwasher and check the thermistor sensor circuit wiring. If the wiring checks out then replace the thermistor sensor.
Parts Required: Thermistor Sensor
Electrolux Dishwasher Error Code 03
Fault Condition: Wash Motor Fail
Repair or Check: Remove power to the dishwasher. Inspect the wiring for the wash motor. If the wiring checks out then check for an blockage in the pump. Replace the wash motor if the pump is not blocked and the wiring checks out.
Parts Required: Wash Motor
Electrolux Dishwasher Error Code 04
Fault Condition: Upper Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan. If the wiring checks out then replace the upper fan.
Parts Required: Upper Fan
Electrolux Dishwasher Error Code 05
Fault Condition: Upper Fan/Vent Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan vent. If the wiring checks out then replace the upper fan vent.
Parts Required: Upper Fan/Vent
Electrolux Dishwasher Error Code 06
Fault Condition: Lower Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the lower fan. If the wiring checks out then replace the lower fan.
Parts Required: Lower Fan
Electrolux Dishwasher Error Code 07
Fault Condition: Drain Valve Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the drain valve. If the wiring checks out then replace the drain valve.
Parts Required: Drain Valve
Electrolux Dishwasher Error Code 08
Fault Condition: User Interface Control Fail
Repair or Check: A switch on the user interface is possibly defective. Replace the complete user interface.
Parts Required: User Interface Control
Electrolux Dishwasher Error Code 09
Fault Condition: Communication Fail From User Interface Control TO Electronic Control Board
Repair or Check: Remove power to the dishwasher and check for any loose wiring connections between the user interface control and the electronic control board. If the wires and connections check out then replace the user interface control. If the problem persists then replace the electronic control board.
Parts Required: User Interface Control - Electronic Control Board
Electrolux Dishwasher Error Code 10
Fault Condition: Electronic Control Board (Relay) Fail
Repair or Check: A relay on the electronic control board possibly failed. Replace the complete electronic control board.
Parts Required: Electronic Control Board
Electrolux Dishwasher Error Code 11
Electrolux Dishwasher Error Code 12
Fault Condition: Drain Valve Position (Drain valve has activated when it should be turned off)
Repair or Check: Remove power to the dishwasher. Check the drain valve wiring for an issue. If the wiring checks out then replace the electronic control board. (This is because the drain valve relay on the control board is stuck) If the problem persists then replace the drain valve.
Parts Required: Electronic Control Board - Drain Valve
Electrolux Dishwasher Error Code 13
Fault Condition: Electronic Control Board Fail
Repair or Check: The control board has a component failure. Replace the complete electronic control board.
Electrolux Dishwasher Error Code 30
Inconsistency between level on electronic pressure switch and level on anti boiling pressure switch.
Electrolux Dishwasher Error Code 50
Fault on the wash motor circuit. On some Electrolux dishwashers the motor has a control board located at the back at the bottom just behind the wash motor.
Jun 18, 2018 | Electrolux Dishwashers
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error 20 (E20) and starts beeping and stops working? Any ideas what it could be? Thanks kindly
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
You will LOVE Electrolux for this... Go to:http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
....and click on START ANIMATION for a complete explanation of how you clean the filter on your machine
Jun 23, 2011 | Electrolux Washing Machines
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
I am having KX-TGA642series codeless phone with
Only stupids buy cordless phone from USA. India uses ETSI DTMF standard for Caller ID which is not supported by any cordless phone sold in USA. It is about time you trash your worthless instrument in the dumpster.
Jun 26, 2009 | Panasonic Lands Phones
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Mothermoard problem
sir i am bharatsinh parmar from india city kodinar state gujarat my mother board display problem
Sep 12, 2008 | Computers & Internet
Service centre in Ahmedabad / Mumbai
I have hp laserJet 3055 black and white printer . Giving sound at start up and while printing
Sep 04, 2008 | SATO CX400 Thermal Label Printer
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
87 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
