Question about Dryers
Lew0050pq won't heat - Dryers
How do I Reset the heat element in my LEW0050PQ electric dryer
you have a venting issue . blown heater fuse. it will do this till you address long ,blocked vent.
Sep 12, 2014 | Dryers
LEW0050PQ dryer works but smells like burning
In many machines, those elements, which are manufactured by "robots", are very cheaply made.
Rather than risk a fire, perhaps an investment of 20 - 30 dollars for a new element might be a good idea.
If you decide to do this, take a second look around for what specifically is getting so hot it is melting.
Likely the loose wire inside the element is doing that problem.
I should guess it is out of it's place and is melting an adjacent wire outside the heating element.
God bless your efforts.
Oct 05, 2017 | Whirlpool GEW9250 Electric Dryer
Re: LEW0050PQ The dryer does not power up. Is it a switch problem?
How new is the dryer? Is the door latching? Check the main electrical breaker for the dryer.
Feb 12, 2011 | Whirlpool LEW0050P Electric Dryer
Whirlpool dryer model LEW0050PQ doesn't heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
Model # LEW0050PQ - The dryer heats and runs for designated cycle time, however does not spin. Will spin if you manyally "push start" it however will get stuck when cycle spin reverses. HELP!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jun 25, 2010 | Whirlpool LEW0050P Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Greeting From Alaska. I have a dryer Model # LEW0050PQ S/N# CAR4502402 that will not heat. The first indication that there was a problem was that the dryer would not shut off when you open the door. It...
either your element is bad,also you could have the neutral wire on the element burned off which will leave you with 240volts across element,you do need the neutral to make elements heat also ckk for 120/240 volts at dryer
Jul 13, 2009 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
16 people viewed this question
Top Dryers Experts
