Question about HP OfficeJet 7410 All-In-One InkJet Printer
Upon start up it just says error:0x886a789e
After about 15 seconds it makes a small (krrk) sound twice
  • 2 more comments
  • treok Dec 03, 2007
    i have the same problem and even though I tried the steps above the problem still persists. Called hp support and all they want to do is offer me telephone help for a price.
  • boysuso Aug 22, 2008
    the probllem is error 0x886a789e and then under it u have 1:??/??/1/2?'?????????#????? something like this
  • belltot Nov 22, 2008
    I have this problem and tried the suggested solutions with no change. Does anyone know what the problem is. Thanks
  • jmk58 Mar 10, 2009
    Any other solutions? Is this fixable by HP, anyone? Or just have to buy a new printer? This was a wonderful printer until this happened!
    Genius:
  • 1,601 Answers
1. Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 1-3 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
2. Perform a partial-full reset on the unit.
Press and hold # and 3 on the keypad and then plug the power cable of the All-in-One.
If the issue still persists
3. Peform NVM RAM reset on the unit :
Press and hold OK and Cancel while plugging in the power cord.
This should resolve the issue. If still persists, please contact HP Technical support for further assistance
Posted on Nov 11, 2007
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
My 2001 ford ranger is hard to start turn the key for 5 seconds let off turn again and starts right up let it sit for 15 to 29 min and hard to start again changed injectors plugs and coil pack runs better...
sounds like fuel pressure bleeding off. Bad fuel pump or bad pressure regulator on fuel rail. Can you hear pump run for 5 seconds when you turn key on? do this twice, 30 deconds apart and see if it starts ok.
Sep 24, 2010 | 2001 Ford Ranger Regular Cab
LED bliks twice. stops for a second, and blinks
It's an error code. Check your manual under troubleshooting or call a Sony service shop with the model number and flash code.
Apr 06, 2010 | Sony Televison & Video
Dryer isn't drying anymore
check the ignitor first it should make a clicking noise within 15 seconds upon turning on the dryer. If no clicking sound is hear you have a bad ignitor for your burner to ignite it
Feb 13, 2010 | Dryers
I replaced the battery. When I connected the - teminal the alarm system activated and I can not start the car
Reach under dash by left knee. There is a 4"x4"x1" bx that has a small wire lead with a small reset button attached. just hold that button for about 15 seconds and it should reset the lights and security system. Make sure key is in on position. Good luck and have a great day.
Dec 23, 2009 | 1997 Subaru Outback
Minimax NT 400 TSI Heater problem
I bet that your 15 seconds of flame are more like 7 seconds. The time is very important. If the flame is not recognized after a specific time the valve is shut off. If the flame sensor is GOING bad but still make some rectification then you may get the issue you are having. I would start with the flame sensor and work from there.
May 03, 2017 | Pentair MINIMAX NT TSI IGNITER
The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
Aug 28, 2009 | Fujitsu Heating & Cooling
T-Mobil Hot Spot at home
It doesn't sound like you're missing something - it sounds like there's a problem with your router. Unplug it for 15 seconds and try again. If that doesn't work, factory-default it by pressing the reset button for 15 seconds and then unplug it for 15 seconds and then try again. (You'll need to reconfigure it after that.)
Are you only having wireless problems, or are you unable to connect via cable, too?
Jul 18, 2009 | Linksys Wireless-G WRT54G Router
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Error message
its the problem of internal white colour cable.
there are two white cables one the front pannel cable and other the scanner cable.any of the two cable could be faulty very rare chance of both faulty but may me faulty.
thanks
Aug 22, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
583 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
