Question about Proform iLog 750 Treadmill
Proform 520
Lost my Proform 520 treadmill manual. My treadmill belt hesitate when you try walking on it.
  • 2 more comments
  • Anonymous Mar 13, 2014
    fixed broken cord now belt keeps stopping
  • Anonymous Mar 15, 2014
    proform treadmill 395 wont turn on
  • Anonymous Mar 16, 2014
    Proform 795 treadmill stops during workout
    change the walking belt on proform 750
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
Slipped belt
there are two bolts on the rear of treadmill walking deck. these are adjustment bolts. start with the belt going 3mph. tighten the side where the belt is closest.only go 1/4 turn at a time.give it 15-20 seconds for belt to track or move over. continue until centered.
Apr 17, 2014 | Proform Pro-Form 520 ZN Treadmill
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
Belt problem
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 14, 2010 | Proform Sport 1000 Folding Treadmill...
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
How do I best maintain the belt on a Proform 525?
read your manual- there is a small section that states NOT to use silicone/wd-40 on your item. You can use only the lube the manufacture(ICON) reccommends. Sears Parts store or parts on Phone 1-800- FON PARTS your part # is 06-831-135855 it is called walking belt lube The retail store does NOT sell this lube, they do sell the silicone spray-but its for the OLDER treadmills I know this I work on treadmills for the company!!!! with a little work, bypass the retailer, go to the source- they charge less...
Jan 07, 2010 | Proform 525C Treadmill Walking Belt
Was just given a Proform 490GS. It has been
Clean item up real good with damp rag-not dripping wet-dust/dirt will hurt walking platform/belt. Icon.com
Icon is the manufacture located in login Utah. Manuals can be downloaded through internet with model# of item, thats located on a silver tag in frt on frame,or under walking platform/mtr hood area. Proform did make one style that the model# was underneth...but thats been 10yrs ago
Jan 06, 2010 | Proform 490GS Treadmill Walking Belt
Pro form 520 treadmill
I lost the manual to the pro-form 520. How do you tighten the belt? Where can I order a new or find the on line manual?
Oct 11, 2009 | Proform iLog 750 Treadmill
Proform iLog 750 Treadmill Logo
1,102 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
