Question about Sharp LC-32AV22U 32 in. LCD TV
How do i fix the lines on the left side of screen going top to bottom???
3 Suggested Answers
ZaneD
  • 41 Answers
SOURCE: Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Posted on Apr 22, 2009
dduncan774
  • 760 Answers
SOURCE: Shadow on Sharp Aquos LC32GA6E
Unfortunatley, they don't make TV sets as dependable as they used too because they don't want them to last. Your problem with this unit is that your panel is going out. Sharp does not supply panels because they are not cost effective to replace. I hope this helped your cause.
Posted on Apr 10, 2012
I have lines on a portion of the left side of my tv
This is a screen-panel issue the only way to fix it is to replace the screen
Jun 26, 2014 | LG 42LC2D 42 in. LCD HDTV
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
Line in left side of screen
bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
Jun 04, 2009 | Televison & Video
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Sharp LC-32AV22U 32 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
