Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony hdtv red lights blinking, make a humming noise when powered on
Recently replaced lamp, no picture, makes humming noise, was working fine then just lost picture
Slinteriors
  • 8617 Answers
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
Posted on Jun 28, 2008
  • 3 Answers
SOURCE: sony KDF-WF655 HDTV Red light on Power/Standby Blinks 6 Times
This is from a repair Manual. You may not be able to do all repairs yourself.
Posted on Apr 20, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
SOURCE: sony grand wega changed lamp tv worked for 10 min
have you check your tiny button on the lamp cover,,
Posted on Mar 07, 2010
Raditronic
  • 196 Answers
SOURCE: Problems with the power on a sony hdtv KDF42E2000
Maybe the probles is with the ballast. the ballast # is A-1247-118-A, no longer available, the replace ballast # is A-1247-19A, is the same.
Posted on Apr 20, 2010
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Tv will not power up - makes a weird noise and red light blinks constantly.
It sounds like a bad lamp, a bad lamp driver or a combination of the two. Be aware that sometimes a bad lamp driver will blow a perfectly good lamp, so if you're not sure which is causing the problem, replacing BOTH would probably be the best course of action
Sep 30, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Jun 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture
replace the lamp and the lamp ballast board using ONLY Sony Parts.lamp A-1606-034B ballast 1-468-798-16 this worked for mine.
Oct 02, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
TV keeps shutting down
Sounds like it may be a bad ballast
Mar 24, 2007 | LG RU-52SZ51D 52" Rear Projection...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
