My roland vs 2480 mouse wont work its stuck in the corner i no there are buttons to push to get it to work i tried shift utility but nothing im clueless HELP !!!!!!!!!!!!!!!!
SOURCE: GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Posted on Jun 01, 2007
jerryg50
  • 1689 Answers
SOURCE: I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
Posted on Jun 04, 2008
SOURCE: roland VS 2480
Press the "UTILITY" button under the Menu heading above the 10 digit key-pad. Under "System Parameter" -Param3, check that PS2 Mouse is set to "ON" and (of course) that the connector is firmly inserted into the mouse connector socket.
Posted on Aug 10, 2008
SOURCE: Logitech MX3200 Wireless keyboard works but mouse does not
i have the same wireless keyboard. i suggest that u redothe setup process and setup the mouse first. if the problem persist then move the wireless scanner.
Posted on Apr 10, 2009
SOURCE: gear shift stuck
I changed the battery but now I cannot take it out of park I have a 2005 Altima
Posted on Apr 22, 2009
How to connect Roland MV-8800 fiber optic to Roland Vs 2480HD
I'm sorry. I have no first hand experience with these units, not to mention, I'm a hardware guy. I can repair it, but I have to look in the owner's manual, just like you, to use it. These are questions you should be able to find in your owner's manual. If not there, check with the Roland website.
Jul 05, 2014 | Roland Mv-8000 Sampling/Record Production...
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
Problem getting VS-2480 to connect to internal drive. also to external drive sometimes it works sometimes it won`t Need service manual for mounting new harddrive internally SATA 160 GB Experienced...
Hi Karl,
First of all, thank you for purchasing the copy of Roland VS-2480 Service Manual.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy.
May you and your family have "Prosperous New Year 2012"!
Again, thank you so much!
Mjsazon
Dec 29, 2011 | Roland Vs2400CD Digital Workstation W/CD...
Roland VS 2480 v2 - working on album and received error message "load project please wait" since last night. have tried turning machine off and on and unplugging it. still same message.
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
Dec 12, 2010 | Roland Vs2400CD Digital Workstation W/CD...
When I turn on my roland vs 2480 it never makes it past the load project start up screen. What can I do? please help
moz-screenshot.pngHave you tried to do a factory reset?
Dec 03, 2010 | Roland Vs2400CD Digital Workstation W/CD...
Jerry G.
Jun 04, 2008 | Roland Vs-2000CD Digital Studio...
Roland VS 2480
May 13, 2008 | Audio Players & Recorders
Roland VS-2480 DVD Workstation
have problem with vs 2480 anyone fixes  roland vs  2480
Apr 10, 2008 | Audio Players & Recorders
Roland VS2000CD
Shelly, I have a 2480 but it must be very similar. Import the drum track as a wav file into two of your tracks within the same project. You must make sure the file is a WAV file and nothing else.
Hope it works, on the 2400, I am sure it must since it is a must have.
Mike
Dec 16, 2007 | Roland Vs-2000CD Digital Studio...
Roland vs 2000cd studio workstation/harddisk recorder.
I have figured out a way to get around this problem without losing your data or sending it to Roland. I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
Aug 10, 2007 | Roland Vs-2000CD Digital Studio...
24 people viewed this question
 Grubhead
Grubhead
