Question about Frigidaire FWSB5700DS Top Load Washer
Crown series 12 cycle washer won't cycle - Frigidaire FWSB5700DS Top Load Washer
4 Suggested Answers
  • 130 Answers
SOURCE: crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 07, 2009
  • 8 Answers
SOURCE: crown series washer shakes violently on spin cycle
When you put on the clothes inside the spinner make it equilibrium to prevent shaking violently.
Posted on Jan 29, 2012
langman_kevi
  • 3 Answers
SOURCE: My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Posted on Feb 29, 2012
Crown series. Why isn't it advancing to spin cycle?
Hey Chuck, thanks for your inquiry!
Based off the information you have provided your Frigidaire washer is not advancing into the spin cycle. You could be experiencing an issue with your timer or wiring harness. I would suggest performing a reset on your washer to help clear out any possible miscommunication that may be within the appliance. You can reset the washer by flipping the household circuit breaker off for at least ten minutes. I hope that this information is helpful to you in some degree. -Matt
Mar 28, 2016 | Frigidaire Washing Machines
My frigidaire crown series washer won't drain the water
water pump knackered or check brushes or if moved washer drain hose kinked
Feb 29, 2012 | Washing Machines
Feb 29, 2012 | Frigidaire Washing Machines
Crown series washer shakes violently on spin cycle
Jan 29, 2012 | Frigidaire FWSB5700DS Top Load Washer
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Frigidaire FWSB5700DS Top Load Washer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
