Question about Samsung BD-P1500 Blu-Ray Player
Blu ray tray won't open no disc is inserted
My daughter pushed the blu ray player tray in to close it faster than it was closing on its own. Now the tray won't open.
4 Suggested Answers
SOURCE: I have a Samsung BD-P1000
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Posted on Nov 27, 2008
noobcybort
  • 199 Answers
SOURCE: when i put a disc into the blu-ray disc player
hello!
theres a problem with the mechanism disk compartment  ie the lens is not being raised up to the position to read disk
When the disk is being taken in the lens is raised up evenly if  not happen no disk will be red .
pls see if the belts are tight or widen if widen needs replacement  because tray does not activate the lens, are some of reasons why the lens can't read .
2, one should check the spinner (disk mortar) if spinning .
3, pls see that the lens is being moved to start position  by its mechanism
Otherwise ur DVD player is fine only the disk compartment .
good luck
Posted on Oct 06, 2009
  • 6771 Answers
SOURCE: I have a samsung blu ray player and the tray won't
The timing gear is out of sync, to reset the gears requires training and skill that cannot be explained on this site, you need someone that knows what they are doing, or the gears will end up getting stripped making matters worse.
Posted on Apr 21, 2012
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
Its says wrong region!
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
May 01, 2011 | Cyberhome DVD320 DVD Player
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
Samsung BD-P1500 Blu-Ray Player Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
