Question about Sharp 25R-S100 25" TV
Zener d732 burn
I want the value of d732 zener diode because it was burn including the voltage regulator ic str w5453a, i want to know its voltege value and power
2 Suggested Answers
  • 6771 Answers
SOURCE: want to know the value at "zd801" on si-727r-ds
The part would run you no more than $5.00
Posted on Jan 01, 2011
Equilent for a zener diode (RD 30ESB2)
Zener diodes are invariably used as low power voltage regulators or as a voltage reference for voltage regulating circuitry.
Zener diodes are sold by wattage and reference voltage by numerous component suppliers and constructor stores and in theory the voltage is marked on them, though difficult to see and easily defaced.
Finding an equivalent for what appears to be a manufacturer's part number presents a rather difficult challenge. The official service sheet will probably provide the required voltage. Without that information you will either have to purchase the component from the manufacturer under the part number or experiment until the required value is discovered.
Mar 02, 2016 | Televison & Video
Please help about the two diodes with color red, red, gray located in power supply unit. The IC switching voltage regulator is STR F6656.What is this diode? It is Zener?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply circuit diagram using STRF6656 is given. There are many TVs using this circuit in the SMPS. You can get details there. Type in the STR number; in the search box at the top right of the display window; to get gathered related posts.
Jul 17, 2015 | Televison & Video
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
What is the zener volt
I'm not sure what your question is. A zener diode is a voltage regulator of sorts. The zener voltage is the avalanche voltage...the voltage that the zener diode will maintain when it's connected in series with an impedance, usually a resistor, IF the voltage across the zener diode and the impedance, in series, is greater than the avalanche voltage (zener voltage), and the polarity of the voltage across the zener diode is thus: positive cathode, negative anode (i.e., reverse bias). The excess voltage (the margin) appears across the impedance. Zeners are often used as voltage reference diodes in regulated power supplies. Does this answer your question?
Apr 16, 2013 | Computers & Internet
I want to know the resistance value of r704 in my sharp 21v-fr7om.. it burn...
leo_arsolaci.jpgleo_arsolaci,
sir here is the exact value of resistor R704- 220 ohms and please check also the zener diode D732- 8.2 volts....
Sep 30, 2011 | Televison & Video
Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
May 07, 2009 | Emerson Televison & Video
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Jul 02, 2008 | Televison & Video
Sharp 25R-S100 25" TV Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
