Question about Crosley CE35100AA Electric Kitchen Range
Brand new crosely oven/range wont heat up displays a f30 code and shuts oven down
2 Suggested Answers
kefford67
SOURCE: No User's Manual
I have a Crosley csf395001 and no manual, how do I turn on self clean option
Posted on Dec 15, 2012
My frigidaire does not heat consistently. F10 fault goes off if it's on for a couple of hours or if we broil. F10 also goes off after cleaning during cool down. F30 goes off after oven is turned off. ...
Good Morning Irene, thank you for allowing me to assist you!
The F10 and F30 error codes are in regards to an open or failed oven sensor. If the sensor and EOC has been replaced, more than likely a professional would need to inspect the wiring harness between the EOC and sensor.
Best regards!
Oct 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our figidaire electronic stove/oven model PLES399ECD, serial number NF62311528, mfg'd 2/2006 has an error code for F30 when any program is selected. The manual does not list F30, what is F30?
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Sep 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
ERROR CODE # F6E1 displays and shuts down oven
F6-E1 - Return Line Not Connected - Replace control board (clock).
Dec 23, 2008 | KitchenAid Kitchen Ranges
See Below. By the way, this is a brand new stove.
if its abrand new stove i reccomend calling authorized servicer. no need for you to void any warr.
Mar 16, 2008 | Frigidaire FES367 Electric Kitchen Range
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Crosley CE35100AA Electric Kitchen Range Logo
23 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
