Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 20 Hp briggs & stratton motor it will run good for about fifteen minuets the gets hot and shuts off,,I replaced the coil and plugs , still does the same ,, could it be the valves ?
    Champion:
  • 225 Answers
Have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
Need to know how to wire a coil on a Diamond I/C 20 hp briggs & stratton motor
Black wire should be an earth for the stop switch. needs to be attached to the switch but not directly to earth
Apr 20, 2013 | Briggs & Stratton Garden
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont shut off
the wires going to the coils are shutoff wires you can run both to a switch and then a wire from the switch goes to ground when you flip switch it grounds the coils shutting off the motor
May 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I HAVE NO SPARK ON MY BRIGGS AND STRATON MOTOR
Try this locate your coil / magneto and disconnect the kill "shut off wire " and try to start if it starts your switch may be bad or wire broken..if still no spark using a rubber handled pliers ...Pull your plug wire and place a screwdriver or similar metal piece and in the plug wire now bring the screw driver close to the engine block or Frame if spark it is your plug..if not your coil needs replaced...not a hard job just use a business card to set clearance on your coil..good luck
Jan 18, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,078 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
