Question about Samsung 50 in. Plasma TV
46rv525u replace sound card - Samsung 50 in. Plasma TV
Hi, sorry for my english. I have Toshiba 46RV525U. The screen have verticals lines and the image doubles, just on the left side.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 08, 2016 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Can a 47" screen be fixed if cracked
Most times buying a replacement panel is more expensive than the tv.
Jul 15, 2013 | Toshiba Regza 46RV525U 46 in. LCD HDTV
2008 toshiba 46rv525u screen cracked but still works. can i fix?
Is not worthy but is you want try any pc repair shop.
Jul 15, 2013 | Televison & Video
Toshiba 46RV525U, Ceramic or Glass 8A Fuse
You can replace it with a regular glass T 8.0 amp fuse 250V and you will be in specs with the original.
Jan 09, 2013 | Toshiba 46RV525U 46 LCD TV WIDESCREEN...
I have a toshiba tv (46rv525u) the power light is just blinking and the tv will not come on.What is the problem?
There a short circuit on the main board and power supply. So your TV is in protection mode and power regulator or H-out. If your are lucky only fuse.
Aug 13, 2011 | Toshiba Televison & Video
The inner screen is broken aproximate cost of repair pleasee
I believe your TV is still under warranty, I would strongly suggest to contact your TV manufacturer so that they will be the one to fix it for free and they also do replacement for a defective unit.
May 13, 2011 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Toshiba HL 52167 HDTV has vertical lines on each side
It appears to be a bad panel. The cost of a new panel exceeds the cost of a replacement TV with the same specifications. If you have a warranty, use it before it expires. If it is out of warranty, I recommend that you complain to Toshiba that this is a common problem and ask for factory warranty consideration. Good luck.
Mar 29, 2011 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Toshiba 46RV525U are JUNK!
The LCD panel is defective. They are expensive. Call customer service and they may extend the warranty for you if you complain enough.
May 27, 2010 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Samsung  50 in. Plasma TV Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
