Question about Frymaster Kitchen Appliances - Others
Flame shooting out back - Frymaster Kitchen Appliances - Others
    Problem Solver:
  • 29 Answers
Does it have a draft inducer(fan) in the back
Posted on Jul 16, 2014
Why does my fryer have flames shooting out of the vent
no doubt grease has been spilled on it sometime and it's burning it off the elements .
Sep 15, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Where should the flame blow when janitrol furnace is ignite?Toward firewall?
It sounds like he incorrectly installed the igniter and it may be a huge danger to your home. A incorrectly installed igniter can cause a excess build up of gas and blow back flame or worst blow up your house. Only have a licensed heating and cooling contractor work on your furnace and not a handy man.
Nov 22, 2014 | Heating & Cooling
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
Why do flames shoot out the venturi tubes and out the front of the bbq control panel after 1 minute of being trned on????
blocked burner , or split burner , gas lighting back to injectors wrong air mix, leak on control panel ,
Jun 10, 2010 | Char-Broil CharBroil Master Flame Gas...
My 2008 1200 sportster is back firing and shooting blue flames since i have installed vance and hines short shots. i also installed the power commander 3 and screamin eagle stage 1 filter. Is it normal to...
Well, yes it is somewhat normal, you have hot rodded it up. What happens is a bit of unused gas now gets buy the cylinder and explodes in the pipe instead of the cylinder. It happens due to scavenging, the new shorter pipes and the better filter allow more fuel to move quicker. If she has a carburetor it will need to be re-jetted but still may shoot flames. If fuel injected she will need dealer help.
Mar 15, 2010 | 2008 Harley Davidson FLHRC 105th...
I rebuilt my motor on my 2002 gsxr 750 over the winter last saturday i took it out and ran fine let it sit over night and in morning wouldnt stay running and back firing and shooting flame out exhaust
Most likely cause is a fouled spark plug. Engines fresh out of overhaul often have this happen as engine oil gets past piston rings that haven't seated in yet.
Remove the spark plugs, clean or replace them. Also check for cracked, damaged, or dirty spark plug caps. This can also cause misfiring and flames shooting from the exhaust.
Mar 09, 2010 | 2002 Suzuki GSX 750
Flame shoots back out of the tube
Try pulling burner tube back (out from chamber) slightly when this happens and see if it makes any difference. Sometimes it only takes 1/4" or less to make it stop. If it won't stay where it burns good, you may have to remove tube from mount and reposition it on the mount.
Jan 19, 2010 | RTO Atwood Water Heater - 6 Gal LP
Loud POPPING noise and flames shooting out the bottom and light
It sounds like to high of voltage was applied or the unit was full of water.
Jan 29, 2009 | Toastess TDF-12 Deep Fryer
Flame shooting to high
call the gas company to have it serviced sounds like it needs it
Nov 23, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
91 people viewed this question
Top Frymaster Kitchen Appliances - Others Experts
Paul Carew
richie46
ray gallant
Are you a Frymaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
