Question about Hammering
How to change drill bit on Kango 340 - Hammering
2 Suggested Answers
  • 304 Answers
SOURCE: need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
Posted on May 28, 2012
MY KANGO DRILL STOPS AND STARTS
test power cable on tensile load because otherwise it will damage one of the 2 electric field coils soon , replace When in doubt, always the powercable.
2 to short brushes or some where a slide contact or suppression coil.
Oct 10, 2015 | Drills
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
I have an old Kango 900 probably produced in the early 70's. The problem now is to find drill bits that fit - any suggestions?
If it the all aliminunm with a blue handle you should have no problem. Go on to ebay.
Jan 05, 2013 | Drills
Need diagram for kango 900 concrete hammer drill
Hi Vicki
May 19, 2012 | Milwaukee Tool Hammering
I have a Kango hammer drill no: 950 No.Identification is 985148.I am looking for the shaft.(10 inch.long) with 2 gears , one a each end .Tanks\r\nYvon
Here is a link. Contact these people. Kango was owned by Milwaukee but you can't get parts from the US anymore. I had to get a part from these folks in the UK.
http://www.knighton-tools.co.uk/acatalog/copy_of_copy_of_Milwaukee.html
Jul 06, 2011 | Electric Drills
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
I have a Kango 950 and it doesn't work properly. When it is plugged in the motor works fine but the chisel bit does not move up and down or even vibrate.
Sounds like lubrication. Used special grease only. May have broken cam. Hammer will run like you say if no load is placed on drill tip. Test it on a rock. Probable rebuild adviseable.
Oct 12, 2009 | Hammering
Kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
Hammering Logo
93 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
