Question about Briggs & Stratton Garden
I am working on a Simplicity Landlord tractor with a 18hp Vangard engine. Will not start when both shut off wires on coils are plugged in. When I disconnect the wires the engine will start. I plug one in and engine will stay running. I plug the second one in the enigine dies. I disconnect one wire from the tractor harness that goes to the coils the tractor will not start until I disconnect one or both of the wires on the bottom of the coil.
    Sergeant:
  • 406 Answers
Sounds like one of the wires are shorted " going to ground " acting like a shut off switch.when connected...try disconnecting the old ones and bypassing them with new ones..see if that takes care of It..good luck.
Posted on Oct 09, 2014
SOURCE: JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Posted on May 15, 2009
backwoodsctr
  • 169 Answers
SOURCE: wiring missing from harness to coil to card
here is a picture from the breakdown of a 15.5 hp briggs engine hope this helps e8059e1.jpg
Posted on Nov 21, 2009
  • 100 Answers
SOURCE: I have a 17.5 hp kohler engine, vertical shaft on
you suspect correctly....
Posted on Aug 14, 2010
roadtech7
  • 293 Answers
SOURCE: Looking for a wiring diagram for Simplicity rider
Have you checked the 20 amp fuse behind the instument panel? It will be an inline fuse. It might be a glass fuse in your tractor. If you taped up the rub through, you should be good after you replace the fuse.
Hope this helps,
Nice tractor by the way.
Posted on Nov 11, 2010
Testimonial: "I did not realize that there was a fuse there, fuel tank covers all of dash inner, can barely see ignition switch. I will check out. Thanks"
  • 173 Answers
SOURCE: No fire comming out of
It sounds like you have a bad coil.
Posted on Dec 29, 2010
Simplicity landlord dlx tractor mower
Try looking at the Governor on the engine. You can usually adjust this out at the Gov arm by loosening and tightening back when smooth. Could also still be dirt in the jets. Make sure all the small holes on he carb are clear and check the float height too.
May 02, 2014 | Garden
1999 simplicity landlord tractor doesn't start
Does it crank? There are a myriad of issues to check
Dead battery
Bad battery connections
Safety switches not all in right setting (like a PTO/mower deck turned on that needs to be off for starting, or a brake pedal not pressed, or a seat not sat on)
Bad solenoid
Bad fuse
Bad relay
Bad starter switch
More details can narrow it greatly. Have you tried jumping it? Do you get noise when you turn the key? Was it an all of a sudden problem, a growing intermittent one, have you tested the voltage of the battery or tried charging it? Etc.
Mar 30, 2013 | Garden
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Dec 02, 2012 | Garden
How to hot-wire a Simplicity Landlord 2010
Why hot wire when you can get a new key. There are only two types of keys.
Feb 01, 2012 | Briggs & Stratton Garden
Garden tools riding mowers simplicity
They do not make that pto clutch anymore but you can buy a electric pto clutch for around $200.00 -$300.00 You will need to check the shaft size it should be 1" or 1 1/8" I could give you more info but you need to find it your self.
Paulo
good luck
Oct 27, 2009 | Garden
Mower turns over but will not start
I have a simplicity landlord tractor that turns over but won't start.
Jun 07, 2009 | Garden
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
76 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
