Question about Drive Medical K318DDA SF Cruiser lll 18 Inch Flip Back Detachable Desk Arms 1 per Case ()
Top of the swing leg where ball bearings are has broken
    Top Expert:
  • 10,875 Answers
No speed is displayed when the trigger is pulled and aimed at the baseball. Just mph and the radar icon. It has new batteries. What could be causing it not to detect speed.
You can add up to 25 miles an hour and more to your swing speed by taking advantage of your hidden, built-in swing speed multiplier. The top pros have always taken advantage of their hidden swing speed multiplier. It's why they drive the ball 280-300 yards The average golfer does not know he has a swing speed multiplier built into his own body-and drives the ball 210-220.
What is the swing speed multiplier built into every golfer? And how does it affect swing speed? It is a hidden lever system that multiplies any increase in hip speed 25 times.
Jun 30, 2015 | Bushnell Velocity Radar Gun Speed...
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
Lost ball bearing unit out of bebe drawer do not want to buy wholt new glides
shops that sell bearings and seals carry a range of single balls for bearing applications check them out.. Take a sample ball in or have the size with you.
Apr 01, 2013 | Bebe Furniture 5 Drawer Flip Top Antique...
Does anyone know how to perform the medicine-ball sit-up exercise?
First you should grab a medicine ball, lie on your back and raise your legs so they're straight. Then you should hold the ball on top of your head keeping your arms straight and not moving or bending your legs and your elbow simultaneously lift your arm and torso until the ball touch your toes.
Aug 05, 2012 | Exercise & Fitness
Can working out with a medicine ball improve my balance?
When using a medicine ball you need to work your core muscles harder; which in turn should improve balance. I was able to find a great tip from a personal trainer in regards to improving balance using a medicine ball - Stand up straight and hold a medicine ball above your head with both hands. Quickly bend your knees and swing the ball down and through your legs, so the ball almost scrapes the floor. Slow the ball down and reverse the motion, swinging the ball back up overhead as you straighten your knees and return to a standing position. Repeat 10-15 times. Do a second set of 10-15 if desired.
We closed up the swing for storage now we need to use it and the seat is wobbly any ideas where to tighten screws?
The main ones to tighten are the ones on the legs that you can see. What makes it really wobbly are the legs not being balanced or spaced apart wide enough. They should be extended out enough for them to be resting on the side of the top where they enter the motor housing, and the feet should be relatively flat on the floor. Push them out (don't force them of course) then use your foot to nudge them out until they're stable enough for your needs. I found it also helps to set this up on a carpet instead of bare wood floor. The swinging motion can sometimes rock the legs up/out a little and make it look unstable.
Aug 25, 2011 | Fisher Price Starlight Papasan Cradle...
My Starlight papasan craddle swing clicks loudly and the gears seemingly miss causing it to not swing properly whenever I put my baby in it (he only weighs 8 pounds). When there is no weight in it, it...
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Jul 19, 2011 | Fisher Price Starlight Papasan Cradle...
When I open bottom or top fridge doors they swing all the way open by themselves instead of staying put partially open
The fridge needs to be leveled better...
When the doors swing open then gravity takes over and pulls the doors open the rest of the way...
to fix this adjust the legs of the fridge so that it leans just a bit away from the hinge side and back just a bit...then the doors will swing closed by themselves...
The back legs may have to be shimmed and the front leg adjustments are usually right behind the front cover at the floor...sometimes there are screws there to adjust the back legs from the front also...
heatman101
Jan 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Oct 17, 2007 | Technics SL-1200 Turntable
Drive Medical K318DDA SF Cruiser lll 18 Inch Flip Back Detachable Desk Arms 1 per Case () Logo
43 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
