Question about Intermatic K4221C Photo Cell Control 120 V 50/60 Hz. 1800 Watt "T" Swivel M
Describe your Intermatic K4221C Photo Cell Control
My lights are turning on at early dusk(still some sumlight)and well after dawn. Is there any way to "open" the lens of the photocell so it receives more light?
    President:
  • 1,723 Answers
It may be your location for the photo cell. There is a cover on the cell in most cases that slides up and down to let in light. Or you may try turning it in a little different direction to get more light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Setting Intermatic HB61R Digital Timer
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
This timer has 1 year limited warranty from Intermatic.
Timer has photo eye for automatic ON at dusk, and has to be turned away from source of light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 02, 2013 | Intermatic K4221C Photo Cell Control 120 V...
Where can I get additional push pins?? Also disappointed that the Intermatic timer 1101 stopped working 13 months after it was purchased. Just 1 month over warranty. Should last longer than the 4 months...
Yeah, I have seen tons of these units fail early. Usually someone stripped the gears.
Another approach, in terms of lighting control, is use dusk to dawn or timed motion sensors. They are always "on time" where the clock needs to be changed many times over the course of season changes, etc. They do not need to be reset after power failure or daylight savings, they just always work/
In a commercial building, interior lights should be on 24/7 OR motion sensors, and external lights Dusk to dawn.
In residential, motion with duration timer systems seem to work the best. Replace the Intermatic. Even the digital Intermatic requires user intervention all the time.
Aug 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Can I use outdoor timer indoors.Its a dusk to dawn timer but no lights will be on
If outdoor timer is programmable, and does not turn ON automatically at dusk, then timer can be used indoors.
If outdoor timer is activated by photo eye, and turns ON automatically at dusk, then it cannot be used indoors, because the timer turns ON when it senses darkness.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB51
Jul 29, 2011 | Intermatic Outdoor Timer/Photo Control...
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
How do I get it to start at dusk and run for 4 hours
You posted under Intermatic make HB51 timer.
To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
Timer turns on automatically at dusk because timer has photo eye.
Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
Feedback from lights will cause timer to reset the 4 hour countdown.
A car pulling in driveway can cause feedback.
If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
Dec 18, 2010 | Intermatic Outdoor Timer/Photo Control...
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
How to program a intermatic outdoor timer/photo control hb51rc
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
Setting
manual for HB51RC
See timer at Amazon
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Intermatic K4221C Photo Cell Control 120 V 50/60 Hz. 1800 Watt "T" Swivel M Logo
467 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
