Connecting my Goodmans GHC50 to the TV
I connect my Goodmnas GHC50 to the tv but i just get a buzzing sound.
Im pretty sure i have connected it properly, and have tried other ways but i get no sound, except from the tv.
shawnlover01
  • 12 Answers
SOURCE: I'm trying to connect my Wi i with my goodmans tv/dvd
it can't becoz it is not the desired model
Posted on Oct 22, 2007
yeokeke
  • 5 Answers
SOURCE: how do you connect headphones to the philips mcd139b dvd micro theatre system?
you need to be sure about what kind of plug do you have...and try with a convert from RCA to your headphone's plug...
Posted on Nov 24, 2007
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Posted on Jan 27, 2008
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
Is the sub woolfer out powered? My sub woolfer is not
Posted on Jun 25, 2008
SOURCE: Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
Have a Vip-722 Dish HD receiver with a Sony receiver w/0 HDMI input and use the optical for audio for the 5.1. Using the HDMI and digital optical at the same time works fine for me.
Posted on Aug 12, 2008
Why doesnt my goodmans soundbar work? It is connected to aux on tv and soundbar only makes buzzing sound
The AUX sockets on the TV are for sending a signal in to the TV. This is what's known as an input.
Signals don't come out of any socket that is labeled in or input. If you want signals to come out of a device, then the correct socket to look for is labeled out or output
The cheapest way of connecting your flats screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
Sep 08, 2014 | Televison & Video
Just purchased a Goodman 50 w sound bar connected to AUX on tv and sound bar clicked AUX on remote white light shows no sound just a loud buzz
To the best of my understanding an Aux port is usually an input port. So you might be sticking the sound bar terminals into the wrong connector in TV. The audio signal from the TV is meant to go into the Aux In port of the sound bar. Usually this will mean a pair of RCA cables (white and red) from TV out to Aux In. If you have done the right things then maybe check if soundbar is not in mute. Try some other source as well. Like connecting an iPhone or ipod stereo out to the Line In port in soundbar and selecting LineIn mode.
see page 7 in the soundbar manual. It is hard to know what TV connection you are using. Is it selected on the TV settings? http://www.goodmans.co.uk/support/downloads/user-guides/GDSB02BT20-ib.pdf
Rca grounding sound with samsung smart tv
I see you are using wireless speakers. The biggest problem with the residential grade is everything interferes with them. Make sure you are moved as far away from power sources as you can be. Direct line of site is not optimal but a fix as well. The wire you have connected for the send receive could be the issue as well. a shielded heavier AWG will help as well as grounding from the source equipment and dropping the ground on the other side.
Apr 13, 2014 | Parrot Zikmu Wireless Stereo Speakers by...
My goodmans tv switched itself off and won't work
Make sure that the electricity is working
Make sure that every connection is in place the
scart connection as well.
Disconnect and wait for 2-5 minutes
and connect and start.
If that does not work look for troubleshooing in the manual or click on the name of your TV here at the top of the page.
good luck
kolbrun
Aug 11, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
I hace a pc cab i connect it to the goodmans x pro
Cant see why not if you have a VGA (usually blue 15 hole (3x5 rows) connection on the Plasma TV, it should be ok. Connect the VGA cable to your PC and then to the TV, then power both up, Search through you TV Sources till you find VGA or sometimes AUX and you will see your PC booting up as normal. Also you might want to put sound to the tv too, in which case you'll need a 3.5mm jack lead at one end (into the sound card Green Jack Socket), to what ever the sound input is on your TV, usually the same 3.5mm Jack. If you want to still use your PC monitor too, you will need a VGA Y splitter, only a couple of quid off ebay, and another VGA cable, about the same price. Hope that's of use to you.
Dec 06, 2009 | Archos AV 500 400-Hours Video Recorder
HOW to connect a wire cable to goodmans GHC50comment brancher le
I would love to help you. I will need a little more information. What kind of wire are we talking about here. Like speaker wire, or video, or rca jack cables?
What is this cable for?
May 23, 2009 | Audio Players & Recorders
Goodmans 289NS standby light flashing amber no picture or sound
50% trouble of tv is lose connection so, try to re solder it but be care of short circuit
Sep 28, 2008 | Goodmans 289NS 14" TV
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
324 people viewed this question
 Grubhead
Grubhead
