Question about ssr 160-TX Pit Bike
What's the best spark plug - ssr 160-TX Pit Bike
How to replace spark plugs in a Chevy Tracker 2002
Here's a Autozone repair guide on replacing your spark plugs,best to use the stock spark plugs. Repair Guides Spark Plugs Wires Spark Plugs AutoZone com
Jul 09, 2017 | Cars & Trucks
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
1984 40hp mariner 2sroke spark plug gap
Need more model information to be accurate and the manufacturer's recommended gap isn't always the best gap for different spark plugs.
In the absence of technical information for the engine the recommended plug gap in the spark plug manufacturer's application catalogue will be the best for that product.
A typical gap for a 2-stroke spark plug with a standard low energy ignition system is in the region of 22 thou. A high energy system will spark across a bigger gap but the spark is typically weaker at hand cranking speeds and so a smaller gap (24 to 28 thou) is still needed for easy starting unless the ignition system is battery powered rather than by magneto.
Mar 24, 2015 | Boating
Spark plug for EJ51LNK
Best to use the plug from the car manufacturer as tests have shown they perform the best for most cars. Call the dealer and but it from them as they will know. I've tried all the performance plugs and dealer is the best.
Sep 22, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
How to repar stripped spark plug threads/ where to purchase?.......???????
Helicoils are the best "at home" repair I know of for stripped spark plug threads in a head.
http://www.stanleyengineeredfastening.com/brands/heli-coil/screw-thread-inserts
Sep 11, 2014 | Motorcycles
What is the best spark plug to buy that will last. I have a 91 mistsubishi 3000gt vr4. Should I splurge for the Bosh Platinum or the BKG. Thanks
Have u heard of 4 electrode spark plugs?
Those plugs are used in the piston powered airplanes!
Its up to u to evaluate it!
Platinum is good, but when it comes to HIGH TEMPERATURE it falters and the center electrode melts down!
Iridium same as Platinum!
The copper core have the best Electrical conductivity!
Its ur choice and experiment to get the best efficiency of SPARK!
Hope that sparks up ur problem!
Dec 04, 2010 | 1991 Mitsubishi 3000GT
1999 chevy k2500,5.7. what are the best spark
The best plugs for a G.M.are A/C Delco.Do not use Champion plugs.You should be able to get these at any parts stores.Hope this helps.Good luck.
May 12, 2010 | 1999 Chevrolet K2500
My truck is a 1996 1/2ton there is gas getting to the engine and there is spark in the spark plugs we fixed the distributor cap and checked all the spark plug wires, the truck will turn over but it will...
Hmm, This sounds like a timing problem.
Best way to do this easily is that:
Take out the #1 spark plug crank/tap motor over until air comes out of spark plug hole--compression stroke(this is "TDC"---Top Dead Center)
Remove Distrubutor cap and check and see if rotor points to #1 spark plug wire on cap----if not move the #1 spark plug wire to that position on cap---then install rest of spark plug wires according to the firing order from the #1 plug wire.
Install #1 spark plug and start truck---you may have to rotate distributor a little bit to get best performance.
Jan 23, 2010 | 1996 Chevrolet C/K 2500
What's the best spark plug for an 2005 5.3 silverado?
the best spark plug....."you know....there is this brand of spark plug"...but they are not really spark plugs they are "pulse plugs" or so they call them........"they are supposed to improve gas mileage and torque and horse power......."except they are like 24 bucks each"...
hope this helps.XD
May 10, 2009 | 2005 Chevrolet Silverado
ssr 160-TX Pit Bike Logo
41 people viewed this question
Top ssr Cycling Experts
John Egan
John Egan
Are you a ssr Cycling Expert? Answer questions, earn points and help others
