Question about Midea Heating & Cooling
Aircon wont turn on - Midea Heating & Cooling
  • 2,133 Answers
Check power and power cable
Posted on Sep 03, 2015
I have a 2004 lancer Es when I turn the aircon on after 15 minutes of driving I cant change the gears the aircon works fine but renders the gears useless and have to turn it off to continue to drive
There is no relationship between the air conditioning system and the gear box in the vehicle.
The engine operates the aircon compressor via the serpentine belt from the crankshaft pulley and if the aircon is operating normally the aircom compressor will not be faulty either.
If you are having problems with the gearbox it has nothing to do with the aircon system. The issue will be with the gearbox itself.
Dec 27, 2015 | 2004 Mitsubishi Lancer
I have a bmw318i e36and the aircon has stoped workingthe gas is alright
have the ac tested by an accredited ac specialist as as the pressure has to be correct to make the system work. The relay is probably controlled by a low pressure and a high pressure switch in the system to protect parts from destruction and by by passing it you may contribute to early preventable failure.
Dec 27, 2014 | Cars & Trucks
My pajero v6 3.5 usually when i turn the aircon on then i shift the gear to drive the rpm just drop and turn off the engine, but withou turning on the aircon the engine wont stop what seems to be the...
the engine doesn't like the extra stress of the air con unit being run _ there is no way of fixing this _ unless you get a full engine overhaul or a secondhand engine and installed _ the engine is old and the extra pressure on it with the aircon it just cant handle it
May 27, 2014 | 2000 Mitsubishi Montero
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
My samsung ac wont turn on at all. according to the wall plug its getting power but when i press the buttons nothing happens, this just started a few days ago
Ok, for the, start if this is a box type aircon, electronic control and solid state thermostat.For the sake of reference.
The problem could be your power outlet lack the other line. Its should be two wire that is completing the power source. Check this first, maybe a troublesome outlet or power plug or the power chord.
Next could be the aircon unit itself, defective power section, or controller section. Blown fuse,lizard insect mouse are common cause.Also bloated or defective capacitor.
But if you are not inclined or do not have any background to electrical and aircon troubleshooting the much safer and practical way is to call an aircon technician. To do the checking for you.
Regards
Jul 09, 2009 | Samsung AW1203B Air Conditioner
My air conditioner only goes for a few seconds then turned off by itself. the technician that i called on the phone said, ''It's probably caused by the unstable voltage from the electricity company.'' The...
i don't what kind of unite you got but that a little strange. most AC unites have dedicated breakers. and do not see what power company has to do your particular house, that wild!
Jul 04, 2009 | Heating & Cooling
Aircon wont turn on
well check ur batteries in ur remote control unit and replace them with new ones instruction to do this u will find in ur user guide......
Mar 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
