Question about Hayward Navigator Pool Cleaner
Navigator keeps climbing up the wall getting stuck under ladder
It seems like it tilted or something it climbs to the top of pool instead of cleaning bottom
    Top Expert:
  • Hayward Master
  • 7,884 Answers
Buy Polaris ladder guards
Posted on Oct 01, 2017
jharwell668
  • 640 Answers
SOURCE: Hayward Navigator sort of floating around by the
I consulter the owners manual for this model. This is what they suggest.
First, remove all of the air from the cleaner head and stop all air from entering the pool through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaners to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Posted on May 19, 2010
  • 366 Answers
SOURCE: We bought new feet for the navigator and put them
you'll need to increase the suction so it will climb. If it used to climb before and now it won't, even with new feet, it may be a bearing problem with either the turbine or the A-frames. You may have to get a turbine kit with a-frames to make it work like new again.
Posted on Jul 04, 2010
jharwell668
  • 640 Answers
SOURCE: Our Pool Navigator gets stuck on the two circular
Here is a copy of the users manual for these pool cleaners. It should be able to find more information about your pool cleaner.
http://www.backyardcitypools.com/images/hayward/Navigator-manual.pdf
Posted on Oct 12, 2010
jharwell668
  • 640 Answers
SOURCE: My Hayward Navigator fails to get out of corners
Check your shoes and wings to make sure that they are not worn and don't have debris lodged in them. Make sure that your hose is the proper length and doesn't have obstructions. It could also be a steering failure. To check for steering failure, make sure that your rear screen is clean, make sure your cone gears are free and clean, and make sure that your gear box is clean and working properly. It is common for these pool cleaners to have one of these problems. Also, make sure that you have the proper tension in your rear flap.
Posted on Feb 01, 2011
jharwell668
  • 640 Answers
SOURCE: I have a Haywood Navigator pool cleaner that
Make sure that your shoes and wings are installed properly and not worn. This is the most common issue with these pool cleaners. Improper water flow could also be the problem. Check with the water flow gauge. Make sure there is no blockage in the cleaner's throat and that there is proper tension in the rear flap.
Posted on Feb 21, 2011
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
The dolphin maytronics does not climb the wall
Thank you for posting your question here on Fixya.com.
Several possibilities to consider...
How old is the filter bag and is it clean?
Older bags or bags not thoroughly cleaned can resist water passing thru them to the point there is not enough downward pressure to allow the unit to 'bite' the pool surface and climb.
How worn are the brushes and tracks?
Worn brushes and tracks will slip once worn enough. Replacing them could fix the problem.
Is it trying to climb or does the unit start up the wall and immediately reverse?
If your motor has been replaced new style motors spend far less time climbing assuming most debris will instead be found on the pool floor. If it has not been recently replaced the program within the motor may be failing.
What is the condition of the pool?
Low water temperatures and/or algae can cause the unit to slip in place and as a result it will not climb. Eventually it will scrub enough to gain traction and will slowly progress up the wall. For temperatures below 70 degrees the unit will find in more and more difficult to climb the lower the temperature.
What material is the pool surface?
Some linered pools and fiberglass pools require climbing rings in the brushes. Do you have those? If so, what condition are they in? Worn rings or missing rings will prevent climbing those and other smooth pool finishes.
For more troubleshooting tips try our site at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. You can also check the manufacturer's site at www.maytronicsus.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Dec 31, 2010 | Dolphin Maytronics Diagnostic Robot...
Wont climb wall
Nov 23, 2010 | Dolphin Maytronics Advantage
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
We bought new feet for the navigator and put them on and it won't climb the walls we tried to to change the seetings to number 3 and it still won't climb.
Jul 01, 2010 | Hayward Navigator Pool Cleaner
Gets stuck on walls
turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Jul 17, 2009 | Hayward Navigator Pool Cleaner
Enchanted climbing level help
I have made to the second climbing level but can't get rid of the giant monster.... It killed me 3 times................... For the first climbing level you have to go where the angry mushroom is and make Gisele walk between the wall and the small vine fence, The best way to do it is to make Gisele follow the wall by going against it. the rest is pretty easy just follow the instructions.( It's the wall on the right)
Apr 03, 2008 | Nintendo DS Console
Hayward Navigator Pool Cleaner Logo
117 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
