Question about Garden
Craftsman manuals online
Don't know we're to check transmission at
  • Garden Master
  • 2,478 Answers
A lot of transaxles are sealed. Go to www.managemylife.com and get your manual.
Posted on Apr 19, 2014
I would like to see a diagram of the pully under the engine.
Rod, Check the attached links,manual,instruction and guides for Lawn tractor. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
917288320 CRAFTSMAN TRACTOR Manual Sears PartsDirect
craftsman dys 4500 belt diagram Google Search
How to Change Replace Main Transmission Drive Belt Craftsman Lawn Mower...
May 23, 2016 | Garden
Will a toro rear end work on a craftsman 42 in?
I'am not sure,but a Craftsman tractor has a Peerless Transaxle,model # LTH2000. You didn't say,if the tractor you have is a manual transmission or a transaxle type.I will say this,that at Craftsman,they usually have their own brand of transmissions. Another brand might not be adaptable. I know this answer,may not be what your looking for.There is so many,ways a transmission can be installed on the different,brand of tractors. I would call Sears,and ask them,if a Toro would adapt,to a Craftsman tractor,you might get lucky. Sincerely,Brad Locke 11/23/15
Jun 26, 2015 | Craftsman Garden
Need manual craftsman 917257550
I don't see this manual available for free online. However, Sears Parts Direct has the manual as part 140952 for less than $5. See http://www.searspartsdirect.com/partsdirect/part-number/craftsman-parts/riding-mower-tractor-parts/140952/0071/917/Model-917257550/0247/1509200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=10032978&diagramPageId=00003&productTypeId=x&searchModelNumber=917257550&subCompDesc=Drive&brandDesc=CRAFTSMAN&modelDesc=IMPROVED-ROCKER-ARM-AND-PIVOT-LAWN-TRACTORS&blt=11&shdMod= to order a copy. There is a second manual, part 140953, that isn't available from the Sears Parts Direct site. It may be available by special order by contacting Customer Service and telling the agent that a "research request" is needed. Provide the model and serial number of the tractor.
I hope this helps.
Jun 06, 2012 | Craftsman Garden
No forward motion
Did you try the Sears web site? Go to the parts direct tab and enter your model number and you can see an exploded view of the drive system.
When the clutch is release, is the transmission pulled turning?
LEt me know.
Regards,
Aug 23, 2009 | Craftsman Garden
Mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere transmission what other mowers interchange
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
Jul 11, 2009 | Athearn N Rtr John Deere Tractor Model B ...
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Craftsman Manual Transmission Problem
check sifter connections/controls for rust or adjustment
change / check the oil is the correct viscosity for the transmission
Jul 31, 2017 | Craftsman Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
