Question about Magellan GPS 315 GPS Receiver
Reset magellan 315
Unit wont turn on
SOURCE: Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Posted on Jul 25, 2007
SOURCE: Case cracking Magellan 315
I was able to open a 315 by starting at the bottom with a screw-driver placed in the gap between either of the two cross ridges and twisting the screw-driver.This opened a gap at the bottom which I followed around the perimeter with the screw-driver until both halves seperated fairly easily.
Posted on Jan 02, 2008
dirinda89
  • 214 Answers
SOURCE: I need an instruction manual for a magellan 315 unit
Sure, here's a link for the manual..
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Good luck, if this helps you plz rate this. Thank you knidly.
Posted on Jan 31, 2009
aloha27
  • 693 Answers
SOURCE: manual for magellan gps 315
Hi1 Here's the link for your manual!
Posted on Apr 10, 2010
kachi_1
  • 677 Answers
SOURCE: Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Posted on Jul 30, 2010
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
Magellan 315 frozen
Things You'll Need:
Tips & Warnings
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
AM LOOKING FOR A MANUAL FOR MAGELLAN GPS 315
(magellangps.com/support/product.asp?prodid=2)
You can use this link to download manual.
Apr 24, 2010 | Magellan GPS 315 GPS Receiver
Firmware Update Fails
I'm not sure this will help, but per Magellan (see below), the firmware update must be run twice as your firmware is earlier than version 3. I have a GPS 315 with v2.03 and can't find a cable to update mine. My GPS 315 does not appear to have a cable connection either, just a screw port on the back for a carrying strap. Was your homemade cable wireless? How did you make it?
You must follow instructions exactly to avoid corrupting your unit's flash memory.
  1. Select the .zip file and save it to your hard drive. Open the .zip file using WinZip.
  2. Connect your receiver to your PC using the PC or Power/Data Cable.
  3. Turn on the receiver and press the NAV key.
  4. Make sure the batteries are at least 50% full.
  5. Select the MAGUP executable file from your PC.
  6. Follow the instruction until you see the message Upload Complete.
  7. If your unit's software version is earlier than 3.00, you will be prompted to turn the unit on again and load the software a second time. Follow the instructions.
Jul 19, 2008 | Magellan GPS 315 GPS Receiver
Magellan 315
That unit does not have a touch screen so holding the screen while powering up wont do anything. I'm not sure which key it is on that model, but to do a reset you hold down one of the keys while powering up. Try holding down the enter key while you power up. If that doesn't work, try again with the other keys until you find it. If it doesn't reset, you may have a dead keypad.
Jan 25, 2008 | Magellan GPS 315 GPS Receiver
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
The only method I have found is with a dremmel tool and cut it open along the original split line.
All the electronics are clear of the case mid line. The case is a bit less than 3mm thick.
The antenna is closest with maybe a 2 mm clearance all round and the various (6) rear conector wires (on the right looking from the back) have a similar clearance but sit below and away when the unit is assembled. Cheers
Dec 16, 2007 | Magellan GPS 315 GPS Receiver
Magellan 315 won't find satellites.
I have one of these units and it too is experiencing the same problem. I have talked to one geocacher and he thinks it could be the connection to the antennae that is now broken. He has a different Magellan unit and he had to fix the antennae connection. I was going to try that on my unit, but I need to figure out how to open it. Hopefully this helps. If I find out more I will let you know. Greg
Aug 15, 2007 | Magellan GPS 315 GPS Receiver
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
Magellan GPS 315 GPS Receiver Logo
93 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
